Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Dec 2006
    R1 Concepts| Front R1 2-Piece Hellcat/SRT 392 Rotors Now Available!
    R1 Concepts| Carbon Alloy 2-Piece GEOMET Rotors!
    Manufactured for european and heavy vehicles, our High Carbon iron formulations enhances noise dampening characteristics, while providing high strength, and increased thermal conductivity compared to standard discs, which increases durability.
    Each rotor is engineered to match the OE vane configuration, including OE split-core technology to ensure proper and maximum heat dissipation. Additionally, all cores are dipped with a specifically formulated paint in order to provide a smoother finish inside the vane structure. The smooth finish will improve air flow as well as reduce the amount of machining require in or to properly balance the finished rotor during the mill-balancing process.
    Fine Turned
    Next, the castings are sent to our state of the art machining facilities, where each rotor is machined to the tightest tolerances available in the market today. We can guarantee specifications of .010mm disc thickness variation (DTV) and .050mm maximum lateral runout. Though in practive, we regularly achieve .007mm DTV and .025mm maximum lateral runout. Then, the rotors are fine turned to a maximum of 1.6 RMS. The objective of these strict tolerances is to create the smoothest possible finish, which improves initial break-in due to the increased contact between the pad and the rotor.
    After all of the machining processes are completed, each rotor passes a 100% electronic inspection station that measures over 20 attributes to ensure that each rotor meets OE specifications. This further guarantees that each and every rotor delivered to you is trouble free.
    GEOMET Finish- The Superior Corrosion
    Finally we apply a genuine GEOMET Finish throughout the entire part, which promises to deliver superior corrosion protection. The GEOMET coating is processed dry, shipped dry, and ready to install without any additional preparation. An average brake job takes 1.25-2.5 hours per axle. Without the need to clean an oil covered rotor, this same a tremendous amount of time and money during the installation process.
    • Superior Corrosion Protection- Provides excellent cyclic corrosion performance when tested to automotive manufacture's test methods incorporating heat, salt spray (withstands 400) and humidity.
    • Environmentally friendly, this meets the following regulations: Environmental Protection Agency (EPA), Chrylser CS-9003, General Motors GMW 3059, Ford WSS-M99P9999-A1 (Hex 9), the EU Directives on End of Life Vehicles (ELV) and Electrical Equipment (RoHS).
    FT/RR CARBON ALLOY 2-PIECE GEOMET ROTORS (FRONT ONLY/SLOTTED ONLY): $1,095 SHIPPED
    FRONT CARBON ALLOY 2-PIECE GEOMET ROTORS (SLOTTED ONLY): $880 SHIPPED
    BRAKE PADS
    R1 OPTIMUM CERAMIC BRAKE PADS
    R1 OPTIMUM SEMI-METALLIC BRAKE PADS
    R1 PERFORMANCE SPORT BRAKE PADS
    HAWK HPS BRAKE PADS
    HAWK HPS 5.0 BRAKE PADS
    HAWK CERAMIC BRAKE PADS
    EBC BRAKE PADS
    FEEL FREE TO EMAIL ME AT [email protected] OR MESSAGE IF YOU HAVE ANY QUESTIONS OR WOULD LIKE TO PURCHASE A SET.
    PERFORMANCE BRAKE PARTS
    1-888-712-6623 ext. 7006
    [email protected]
    *Current forum rotor and pad deals: http://www.lxforums.com/board/showth...02#post2994702
    Likes cowboysfan72 liked this post
    Oct 2016
    Wartburg, TN
    How much weight savings over OEM?
    Sent from my SM-S975L using Tapatalk
    Dec 2006
    These are pretty much the same weight as the OEM rotors. Exact weight is 30.65lbs each. Only difference is you'll be saving a lot more money going with these aftermarket rather than going with OEM rotors which are at least over $1K.
    Jun 2016
    Are these only for the 6 piston calipers, or is there an option for 4 piston calipers?
    16 Charger B5 R/T "JUSTANRT" - Inertia Cam, Manton Push Rods, 180* T-stat, LMI True V2, ARH Long tubes and catback, BC Racing Coilovers, BT Catch Can. Built by EMP
    Dec 2006
    Quote Originally Posted by Abruskii View Post
    These rotors only work on the Hellcat and SRT 392 models.
    Dec 2006
    Bump
    Dec 2006
    Weekend bump
    Dec 2006
    Bump
    Dec 2006
    Weekend bump
    Dec 2006
    Bump
    Nov 2014
    I’m curious, what are the benefits of two piece rotors?
    Sep 2014
    Quote Originally Posted by BradJo9 View Post
    For racing, they save weight (aluminum hat), typically have a little bit better venting/cooling, less heat transfer to the hub, more uniform heat across the rotor (less warping), etc...
    For street-based muscle cars, they just save weight by making your wallet a lot lighter.
    Thanks r1concepts thanked for this post
    Likes MeanGreen1o1, UpInSmoke, agoristmike liked this post
    Dec 2006
    Bump
    Dec 2006
    Weekend bump
    Dec 2006
    Weekend bump
