Results 1 to 2 of 2
Thread: Bag Replacement
    Apr 2012
    Bag Replacement
    Hello, I have the Complete Air Suspension Kit for 300/Magnum/Charger/Challenger. I need to replace my rear bags. Two questions.... The "Air House 1" seems to be the correct replacement.. However I'm not sure what size port 1/2" or 3/8" The bag is still on the car otherwise I would of tried to match it up... The only thing I know for sure is that the Air line is 1/2"OD and 3/8" IN... Which would i select for the port on the replacement bag.. Also, How much is it for me to send one to get rebellowed so i can have a spare the current ones look like they have tiny cracks from dry rot... Thanks!
    Mar 2006
    San Bernardino, CA
    Typically, for a 1/2" hose, its going to be 3/8" npt. However, there is a possibility its a 1/2" npt, but, typically it would cause the fitting to hit the cone of the body. If you want to play it safe, you can pickup new fittings for the rear, or pull it out and double check. The outside of the threads on a 1/2" npt is about 3/4", and 3/8" NPT is about 1/2".
    To replace the outside bellow its $45.
    Zack Ratcliff
    Universal Air Suspension
    http://www.UniversalAirSuspension.com
