Results 1 to 5 of 5
Thread: 2011 TCM Tuning
    Jun 2013
    Green Bay Wisconsin
    2011 TCM Tuning
    Hey folks,
    I've been considering getting a tuned TCM for my 2011 Charger to take advantage of my cam swap a bit more. Suggestion from MMX is 6000-6200 shift points and right now its stock shifting at 5500. But I am looking for recommendations on who is best suited to buy the TCM from? Also do you recommend buying another TCM and having it tune vs sending in the original? If I did buy another TCM, I assume the part number would have to match? Anyway, any ideas, experiences and light to be shed are all welcome. I haven't read much on 2011+ on the forums, most people all talk about the MPTCM for the earlier years.
    For the record, my car is a 2011 Mopar11 Charger. 5.7, stock heads and rotating assembly, MMX custom cam with PSI springs, shorty headers, Dynomax cat back and a Hemifever custom tune on 93. Running stock 3.92 Getrag LSD diff and stock converter with NAG1. Car is not really on the track, I plan to do a drag race here and there, but mostly its just a street driver.
    Mopar11 Charger, MMX Cam, BBK Shorty Headers, Hemifever tune, Getrag 3.91 LSD
    Jan 2011
    Calabash, NC
    AJ (hemituner) if he is still doing them.
    PB 0-60 3.24 MIR Raceway Drag Radials 6/18
    PB 60' 1.472 @ CF9 4/18
    PB ET 1/8 6.911 @ CF9 4/18
    PB MPH 1/8 101.32 @ The Rock 4/19
    PB ET 10.857 @ CF9 4/18
    PB MPH 127.29 @ Atco 11/18
    Thanks kb67mopar thanked for this post
    Nov 2013
    South Florida
    I would go with HemiTuner. I bought a new TCM from him and its been excellent for the past 5 years.
    2006 300c SRT8
    PWR Ported Heads | HHP Stage 2R Cam | 3.91 Getrag | GTP Ported Intake Manifold | Kooks Longtubes | Corsa Sport / SRT Resonators | AMG 8 Piston Brake Calipers | Hemituner 6,800 TCM | BT Catch Can | LMI True CAI V2 | Tranzformer | MM 87mm TB | Johan Tuned | REM Adjustable Endlinks & Front/Rear Shock Braces | 33/22mm Front/Rear Sway Bars | Michelin Pilot Sport 4S 305/35/20 & 275/40/20 | 10" Widened Oem Wheels | LC-2 Wideband Analog Output to Trinity | Mishimoto Full Aluminum Radiator
    Apr 2016
    Toledo, OH
    Go HemiTuner and don't look back
    Mopar 11
    (SOLD)2012 Charger R/T Plus: Diablo I2 w/ Hemifever 93 tune, stock 2.65's, JBA shorties, catless mids, dual 12" Cherry Bombs, reso delete, catch can, 180* t-stat, Mopar CAI. Best 1/4mi: [email protected] (street tires @ 934' DA) at Milan Dragway
    Nov 2013
    Hi,
    Not trying to hi-jack the thread but, I have a similar setup and have questions about how you guys installed your new Hemituner (AJ) TCM’s. This could be useful information for the OP as well if he decides to go with AJ.
    I currently have a HemiFever tune in the car and have been told that the AJ TCM should “just work” with it. I take that to mean it’s just a remove & replace, plug & play operation.
    I’ve also been told that the best way to do it is to:
    return the tune back to stock, install the AJ TCM and save an “Original Backup” with the new AJ TCM and then install my Diablo or Custom tune?
    My question is will my HemiFever Custom tune still work with the “new original backup” since it was created using the other “original backup”?
    Would I need to have a new tune written with my “New” original backup that uses the AJ TCM?
    Thanks in advance
    I
