Results 1 to 9 of 9
Thread: ECU VIN change
    Apr 2009
    LX ECU VIN change
    All,
    I recently bought and installed a 6.1 engine with harness and ECU. Where would be the best place or method to get my cars VIN into the ECU? Also, does anyone do tunes for stock engines? Maybe just a bit more timing, better throttle response, small tweaks like that? Car is a 2008 Magnum R/T. Engine was pulled from a 2008 Charger SRT8.
    Jun 2015
    Southern Connecticut
    You can do it yourself with AlfaOBD or Appcar's DiagFCA.
    "Many true sports cars can be outrun by a powerful sedan." - Sir William Lyons, Chairman, British Leyland
    Jan 2019
    Ottawa, Ontario, CANADA
    I can do the VIN change. I can also reprogram your old 5.7 ECM with 6.1 programming so that you will have a backup. Send me a PM if you are interested. As far as small tweaks go, a Diablosport tuner really wakes these early cars up! You can get used ones on the forum here for pretty cheap. I saw one a few days ago for $150 I think.
    Feb 2019
    Milan, TN
    Quote Originally Posted by CtCarl View Post
    With alfaOBD? ive had that program for some time and have never seen its ability to do that or change cluster mileage. Which is why i got it originally
    when they made me they broke the mold, and beat the piss outta the mold maker....
    You just started reading the sentence you just finished reading...
    Sep 2018
    Springfield, MO
    I don't think either program can change mileage, but I know for sure appcar can change vin's on pcm. Had to do it with mine when I did my nag1 swap.
    May 2020
    Charlotte, NC
    Quote Originally Posted by Ultimagic5 View Post
    Ik I’m bringing up a dead post, but appcar can? I’m doing a rt awd to srt rwd6.1 swap
    Sep 2018
    Springfield, MO
    Quote Originally Posted by Willhart18 View Post
    Yes
    Apr 2020
    Ontario, Canada
    I don't have appcar, but I do have Alfa. On these older PCMs, on an older revision, it could not. Maybe the newer updated version can.
    However, you will need more than a vin swap when going from 5.7 RT to 6.1 SRT. The fuel map is different as well there is no MDS nor EGR in the 6.1, but there is in the 5.7. so you will have to turn off MDS and EGR as well as tune it for the 6.1. I don't know if any of those apps can do it. I have never tried with Alfa.
    May 2020
    Charlotte, NC
    Quote Originally Posted by Myckee View Post
    I’m having johan tune it after
