Results 1 to 5 of 5
    Mar 2017
    Bedford, Texas
    Wideband preference?
    Hopefully I stuck this in the right hole :-)
    Since DS has finally gotten the analog deal fixed, I'm about to drop the hammer on a wideband kit.
    Does anyone have a preference? Is any one better than another (obviously exluding the eBay specials)?
    I'm eyeballing the AEM UEGO 30-4110, but if someone knows of a better one, I'm open to suggestions.
    Mar 2016
    Ive been happy with my Innovate MTX-L. Has 2 programmable analog outputs.
    Mar 2017
    Bedford, Texas
    I debated running 2, but it won't be necessary until I forge and boost it. Even then I think I'm going with a 6.1 intake for simplicity's sake. Thanks for the input I'll look it up.
    Dec 2008
    NH
    I went with the AEM one as most of the research I did showed it was faster than the others.
    Calgary, Alberta
    Zeitronix ZT-2
    No gauge, as the output is integrated into an Aeroforce Dual OBDII Gauge system located in the A-pillar.
