Results 1 to 12 of 12
Thread: Fan settings
    Apr 2010
    Durhamville,NY
    Fan settings
    Just wondering what everyone is doing with fan and coolant temps. I have a 16 scat pack with a 180* t stat a T 2 Trinity, cruising at speed temps are fine 183 to 185, as soon as I stop they go up,209 to 212. The main problem is at the track,in the staging lane the temps go up. my older 09 temps stay the same. I know the trinity says desired temp which I set at 173* but the fans don't even come on while at a crawl. What is everyone else doing to keep temps down?
    Thanks
    392 thitek heads and twin 62 turbos.10.20's 0n 10lbs,lot's of Hp on tap. Old set up 427 eagle. http://youtu.be/F1twEKaSQHs http://youtu.be/461fZ5OpH8c
    Corona, CA
    Do you have a Diablosport Predator or Intune? You need to go in and adjust the fan setting temps...
    2006 Charger SRT8
    MPR Motorsports installed 6.1/392 NA Stroker, BBK 85mm TB, TranZformer, Kooks Long Tubes
    Mar 2018
    Trinity couldn't adjust my fan settings when I had my 12-14 charger, it just made you think so.
    Jun 2007
    Sanford FL
    Quote Originally Posted by Chargerrich View Post
    How so exactly?
    Mar 2018
    I would tell it 180 and it wouldn't change the car....it would still go to oe temps. This was 3-4 years ago maybe its different now.
    Old Hickory, TN
    Quote Originally Posted by kbr577 View Post
    Thanks
    There is no need to set the fans that low. I have mine set at 195 and 205. The issue at the track is different. You need to have a fan override that will force the fans to run from the accessory position of the ignition so that the fans are running while you are in the staging lanes.
    Apr 2010
    Durhamville,NY
    Working with Mike on this, we all use are cars a little different, I would like to run cooler all the time.
    Thanks for the input!!
    Apr 2010
    Durhamville,NY
    Quote Originally Posted by netnathan View Post
    Trinity T-2
    Old Hickory, TN
    To accomplish what?
    Jun 2007
    Sanford FL
    To accomplish what?
    I sent him a new tune to try with some other fan changes that aren't normally needed on these cars.
    Thanks
    Apr 2010
    Durhamville,NY
    Thanks
    Should get it in tomorrow.
    Mar 2017
    Bedford, Texas
    Let me know if it helps, I may ask Mike to do the same for me. I'm not a huge fan of 208-210° in traffic either lol
