Page 5 of 5 FirstFirst ... 345
Results 61 to 64 of 64
Thread: Appcar DiagFCA
  1. #61
    Mar 2017
    I want to simply update my TCM. I have a 09 Ram 1500, I recently had to do a Cam and Lifter replacement. After completion, the truck is stuck in reverse. Manually shifting the lever on the side of the transmission doesn't change anything. I talked to a Dodge service tech and he said the TCM needs to be reprogrammed. Is this something that can be done with Appcar? Also is it possible to download the updates from Mopar Tech Authority and reprogram the ECM/TCM?
  2. #62
    Jan 2018
    Quote Originally Posted by Creamed12 View Post
    No, can't do with Appcar, and definitely not TCM software issue. How could cam swap affect TCM? Broken/pinched wire, bent pin in a connector, forgot to plug in some connector, blown fuse...
  3. #63
    Nov 2009
    Niagara Region,Canada
    Question I have...do you need to back to google only, or can you backup to a usb key, ext. drive...etc?
  4. #64
    Feb 2012
    Okeechobee, Florida
    I know this is getting into zombie thread, but I was able to get my Homelink working once I installed the wiring and the module of course. Ten minutes later, pushed the button and up the garage door went. I was at the dealer getting a free oil change, and the tech was asking me how I got all those things working without the Starscan. He was pretty impressed with what the software could do.
    Ron
    ...Semper Fidelis...
    Likes tripstuf2 liked this post
