Results 1 to 4 of 4
    Mar 2016
    N. GA
    How Does One Inspect Half Shafts For Condition, On Bench If Necessary?
    I have 140+k miles on the OE half shafts and Hubs. Everything is quiet and smooth. A recent drive shaft and couplers.
    I'm going to be under there in coming weeks swapping out the open 3.06 Diff with another of the same converted to Wavetrac LSD.
    I can checkout the hubs no problem but have no experience with CV axles. This is my 1st independent rear suspension. The diff will be out so I could just pull them and have a look. Not sure how to inspect while installed other then the obvious.
    I want to know how to really inspect them for signs of wearing. Or...............
    The other part of me says, over 140k miles, a Supercharger added @128k dynos' 459, and going to LSD, just change em now? I would be going MOPAR OE R/T axles and SKS hubs.
    Prepping, waiting ring gear bearings and the Wavetrac.
    2013 Dodge Charger R/T Plus, Edelbrock E-Force 2300TVS 6.8 PSI, 450hp/459tq, Corsa CatBack, 3.06 Open Diff, Severe Duty Radiator, Dual Fans, OE Oil Cooler, Pursuit BR9 Brakes.
    Mar 2016
    N. GA
    No one?
    Calgary, Alberta
    The halfshafts are only serviceable (rebuilt) by those who do it for a living. As such, there are not replacement parts outside of boots (which even then require the skillsets to R&R).
    If they are serviceable, produce no noise, keep using them.
    Note that replacing parts that are in good / serviceable condition - just because one has the system disassembled - is questionable at best...
    Likes Hemihackman liked this post
    Mar 2016
    N. GA
    Thanks, I have no experience with them so I had to ask.
