Results 1 to 10 of 10
    Corona, CA
    Is a Nag1 a Nag1? Are they all the same?
    Are all Nag1 trannys the same from 2005 and up? including bell housing bolt patterns and length?
    I had heard a rumor that the SRT8 Nag1 was a little beefier...true?
    2006 Charger SRT8
    MPR Motorsports built 6.1 based/392 NA Stroker, BBK 85mm TB, TranZformer, Kooks Long Tubes, 3.70 LSD Hellcat rear cradle
    Thanks Ultimagic5 thanked for this post
    Likes Ultimagic5 liked this post
    Sep 2018
    Springfield, MO
    Also curious
    Jan 2016
    From what I have read they are all the same. Except AWD and RWD. Torque converters are different in body styles -engines ect.
    Calgary, Alberta
    Other than a couple of different torque converter offerings, all Chrysler-based NAG1s (New Automatic Gearbox Generation 1) / WA 580 (Wandler-5-Gang-Automatik w/ 580 Newton Meter capacity) offered from 04' through 08' are copies of the Mercedes 722.6 series Mercedes transmissions. Maybach, Porsche and Jaguar are a few of the other marques that employed / employ the same transmission.
    Corona, CA
    Other than a couple of different torque converter offerings, all Chrysler-based NAG1s (New Automatic Gearbox Generation 1) / WA 580 (Wandler-5-Gang-Automatik w/ 580 Newton Meter capacity) offered from 04' through 08' are actually 722.6 series Mercedes transmissions. Maybach, Porsche and Jaguar are a few of the other marques that employed / employ the same transmission.
    So.... then only AWD drives (and jeeps) are different only because of the outer case?
    Will a 6.4L 2014 Nag1 will bolt to a 2006 SRT8? How long was the Nag1 supplied?
    Calgary, Alberta
    [QUOTE=netnathan;5174908]So.... then only AWD drives (and jeeps) are different only because of the outer case?
    Will a 6.4L 2014 Nag1 will bolt to a 2006 SRT8? How long was the Nag1 supplied?[/QUOTE
    Outer case and for example the Jeep had the same higher stall TC as the SXTs. 2014? Should, I have what has been deemed the very last factory brand new NAG1 available - in the Magnum.
    May 2012
    piedmont, NC
    I've read somewhere that Charger Pursuit still uses the NAG1, anyone confirm?
    Oct 2011
    PGH
    Quote Originally Posted by pursuitlx View Post
    I remember reading the same in Allpar or such. The Pursuits get a column-mounted shifter rather than console-mountes to free up room for gizmos. From '15-present FCA hasn't adapted the ZF 8-speed for column-mounted Pursuits.
    There was a W5A330 lower-torque transmission as well but don't know if/what Daimler-Chrysler used it in.
    FURIOUS FUCHSIA 2010 Challenger R/T Classic A5
    FLOW Legmaker intake, Belanger Tri-Y headers, Zoomers catback, Joelvan's p/s pulley & Russell cooler, 392 front clip // GO 215mm Wavetrac LSD, AMG diff cooler & BlueTops, B&M pan, Tranzformer & NoESP // WHOA RideTech coilovers, Hotchkis sways, PowerGrid endlinks, REM bumpsteer, REM & Petty braces, CTP/BFNY solid cradle bushings, AAD harness bar w/ Sabelt 6pts // SLOW Serious Metal SRT 14.2 front & Pursuit BR9 13.8 rear rotors, Carbotech pads, Russell lines // SHOW WebElectric, Hurst, Billet Tech, RiderGraphix, Performance Pedals
    Thanks pursuitlx thanked for this post
    Jan 2014
    06-08 SRT's has a 4 bolt yoke at the tranny and differential I think. Thats the only difference.
    06 Black Mag R/T. Rear wiper delete, trunk handle delete, front and rear aluminum belly pans, Strut grills, Spectre drop in , straight pipes exhaust, 85mm Arrington throttle body, diablo sport Intune, Jet 180, billet catch can, st coilovers,spc adjustable upper control arms, BWoody endlinks, Petty's garage sways, speedlogix 4 point rear strut brace, Pettys garage front strut tower brace, long tubes, 2015 eagle intake, SLP Underdrive pulley, Getrag 3.91-axles/hubs, BMR rear suspension
    Corona, CA
    I have a Nag1 manual, if someone can tell me how to upload a pdf
