Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
  1. #31
    Aug 2009
    Quote Originally Posted by Slated4Greatness View Post
    Wouldn't a bound transfer case do this?
    Going tomorrow to a shop to talk about this.
    05 Magnum AWD SXT Hemi Swap
    instagram.com/hemisxt
  2. #32
    Feb 2018
    Tampa Florida
    I would like to see a better pic of one of the damaged inner joints... From what i can see it looked like the inner Plungimg joint was being over extended. This could be a mount issue, suspension bushing issue on even a subframe shift issue. Lets see some better pics of those inner joints.
  3. #33
    Aug 2009
    Quote Originally Posted by Lenny H View Post
    I would but they have gone back as core returns so I don’t have them. In the meantime I took apart my front differential and.... nothing. Everything was good.
    So with all that I’m putting in this newish transmission.
    Rear wheels only.
  4. #34
    Southport, CT
    Hey, sorry to hear about your axle woes, but thanks for posting this info for everyone. This might be a dumb question, but I figure I'll throw it out there; if there's no binding on the transfer case differential side, is it possible there was binding on the wheel side? By that I mean could there be binding on the wheel hub that could have caused the axle to snap?
    As far as converting to RWD, are you planning to keep all of the AWD steering, front suspension, and brakes intact?
    2006 Black Magnum RT AWD - Sidewinder Cam * Ported Heads * Edelbrock Shorty Headers * Cherry Bomb Vortex Cat Back * SLP Dual-Wall tips * Volant CAI * Diablo Trinity * Johan Tune * KW V2 * 2013 Dodge Charger 19" AWD Wheels *
    2010 Black Jeep Commander Limited
    Thanks pursuitlx thanked for this post
  5. #35
    Nov 2011
    Ontario,Canada
    Is it staying off the lower control arm mount?
    ·Ï¢årµ§·
  6. #36
    Feb 2017
    I'm sorry to see this Rob.
    I'm thinking of the same to convert my awd to rwd.
    However, parts are so hard to find here in Switzerland. Especially an SRT to get the part from.
  7. #37
    Aug 2009
    Quote Originally Posted by Rottyfan View Post
    No dumb questions man... I'll take any and all. As for your question- I thought about that but all the CV joints on the inboard side broke. Wheel ends have been fine.
    The conversion- I kept all AWD cradle, brakes and suspension. I'll tackle that later on down the road. I can get engine cradles all day long at the local auto wreckers so that's on the to-do list.
  8. #38
    Aug 2009
    Quote Originally Posted by IcarusLSC View Post
    It was, yes, as far as I could tell.
  9. #39
    Feb 2017
    glendale az
    Rob, I hope you find root cause. I hope you don't mind - but I'd like to point something out to the rest of the readers...
    Given the vehicle had operated nominally for an extended period of time without issue, one failure of this magnitude should have prompted an investigation to find out why.
    Failing that, a second failure in quick succession would make finding root cause - mandatory.
    A third(!) failure in quick succession is foolhardy, with previous proof the same exact event was pretty-well a guarantee.
    A forth is, well...your backyard mechanic's license should have been revoked after the second failure :^)
    For everyone; do not, repeat do not, simply throw parts in place of broken ones without(!) determining why it failed in the first place.
    The definition of insanity is doing the same thing over and over again, but expecting different results.
    The root cause of breaking inner c.v. joints is improper angles, they break very quickly in fact. Im not sure if his motor mount are collapsed paired with the fact he is already stressing them with the lowering kit but angles is the cause, he just needs to find the culprit. Is the subframe correct for the setup he has? Has he changed the mounts recently? Are the mount degraded and sagging allowing the entire powertrain/axles to hang down lower than they should. Some pieces of the puzzle need to be put together here... I noticed in one of your photos looks like you have one bolt coming thru the subframe bracket into the engine mount??? It has a fresh mark on it like it has shifted or been off recently, can you explain whats going on there?, might have weight in this matter...
    Likes SCOTT57RT liked this post
  10. #40
    Aug 2009
    Good points. Did my hemi swap two years ago and everything is solid. I’ve been lowered for 10 years and nothing like this has happened. The subframe and mounts are correct, and like I said- absolutely everything has been 100% solid for years now but one day out of nowhere...
    Either way I took all that nonsense out and converted to RWD. I’m very happy with my decision.
  11. #41
    Calgary, Alberta
    Quote Originally Posted by circ1977 View Post
    And there's the rub; Rob's Magnum has been lowered for years - without a single axle failure. So the premise the axles were being stressed doesn't hold water.
    What root-cause is we'll likely never know...
