Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Feb 2012
    DFW-Texas
    Trans pan drop question on a 2008 challenger SRT8
    Hey boys,
    I have a 2008 challenger SRT8 with the NAG1 transmission. I bought the Mercedes trans pan with the drain plug in it to make future trans maintenance easier, but I noticed when I got under the vehicle to remove the pan, that the two rear most bolts of the trans pan are blocked by a large cross member that would need to be removed to access those bolts with the T30 torx socket and a ratchet, or to use a torque wrench to tighten them back to 70 in/lbs.
    Is that cross member supporting the transmission or anything else I need to know about before I remove it? Does anything need to to be braced before I pull it off? And what is the torque on the bolts on the brace when I go to replace it back on the car when I'm all finished?
    There's no mention of a cross member on other challenger articles on trans maintenence that I've seen, so I'm thinking it's unique to the SRT models and I just want to be sure I don't fudge something up before I pull it off.
    I have a Dorman dipstick, a Tranzformer to get the fluid temp and the temp/fill chart, just don't know about that brace.
    No need to remove the crossmember in my opinion. I removed mine without doing it. And I didn't torque the bolts either. 60 or so years of shade tree wrenching makes me think I don't need to to seal the pan with a gasket. Change that filter. they can plug up.
    Sep 2012
    chicago il
    Removing it makes it easier. If you do just support the driveshaft. Just like above, change the filter.
    2007 SILVER CHARGER SRT: OBX LONG TUBES, NO CATS, MAGNAFLOW MUFFLERS, SRT MAX CAM, BFNY PORTED 6.1 HEADS, LMI TRUE CAI, 3200 ENHANCED TRANSMISSION CONVERTER, 3.55 GETRAG/UPGRADED CLUTCHES, 180* T-STAT, ATI FLEXPLATE, EUROCHARGED TCM, PORTED INTAKE AT TB, 90MM BBK TB, DIABLOTOONA TUNED.
    2007 BB CHARGER R/T- 400ci stroker, big cam, hellcat rear cradle conversion with 3.09zf diff, to much to list.........oh yeah, procharger d1sc at 15#.
    Calgary, Alberta
    Quote Originally Posted by aim4squirrels View Post
    Hey boys,
    If you've got the appropriate tools (like ball end keys), you can work around the cross member, but yes, it supports the back of the transmission. That cross member supports the transmission assembly so if you elect to remove it you need to put support forward - under the transmission.
    Feb 2012
    DFW-Texas
    I didn't even know they made ball end torx wrenches. Thanks for the tip, Simon.
    Nov 2009
    Niagara Region,Canada
    Watching videos of people draining the nag1 is just fxxked. Watch as they get fluid everywhere. What I do and I'm sure some other do as well. Warm up the car so the fluid flows. I use an fluid extractor, stick tube down trans tube. Pull fluid from trans. Jack car up, support it, pull pan. All without get trans fluid everywhere. Hope that helps you out!
    It would take longer but you can use a piece of tygon tube from Home Depot to syphon the oil out. I have siphoned oil out of my transmission using this technique.
    Feb 2015
    When I changed my filter a few years ago, I put a jack stand behind the cross member. Below the output of the transmission there's a part that sticks past the cross member, I got the jack stand as high as it could fit and lowered the cross member, the bolts are pretty long.
    Actually just found pictures, this was in 2015.
    Sent from my SM-N900V using Tapatalk
    2005 Brilliant Black 300C
    Qtp dual oval cutouts, LegMaker True V2 CAI
    ZAuto Tranzformer, Diablo Trinity 93 canned tune, Hoosier Dr2
    Nov 2016
    The 4 crossmember bolts are 75lbs and the 2 trans mount bolts are 55lbs. Use blue loctite.
    Feb 2019
    Replace the trans mount while yer there. Unless your car has 50k miles or less. It will thank you for it ..l0l
    Calgary, Alberta
    Do not use Loctite!
    Calgary, Alberta
    Quote Originally Posted by GreyMax View Post
    Do not use Loctite,
    Quote Originally Posted by Mopar'er no car View Post
    If it's serviceable, why? It sees no appreciable loading.
    Feb 2019
    Do not use Loctite!
    I agree on the aluminum housing/mount bolts but a dab of blue wouldn't hurt anything on the crossmember bolts.
    Feb 2019
    Do not use Loctite,
    1. The rubber is old.
    2. You are in there already and only have the mount to remove.
    3. Even the one in above pic is showing wear/distortion
    4. Preventative maintenance
    5. Engine mounts and trans mount hold Engine/trans assembly (as stated above)
    Calgary, Alberta
    Why???
    <sigh> Huh?
    1. How do you know "the rubber is old"??
    2. Why? If its serviceable, why??
    3. BS, there's nothing in that pic to suggest there's anything wrong with it, plus its not the OP's car!
    4. BS again
    5. This device can not be compared to engine mount loading.
    Flawed logic, waste of money.
