'07 Charger R/T stock gear box upgrade...
4K views 5 replies 4 participants last post by  HemiLonestar
#1 ·
Hey people. Im wanting to upgrade my '07 Charger R/T rear stock gear box with a stock SRT8 (05-'10) 3.09 gearbox but have some questions? Could I use my existing axles? Could I use my existing hubs? I do have the Diablo Sports i2 inTune which I will be able to change my gearing in the computer. Thanks!
#2 ·
You will need new axles and hubs. If you use a 2012 SRT rear diff, it is a three bolt flange just like on your car, so you won't need a new driveshaft. You'll need pink bolts and nuts for the rear diff coupler, new axle nuts as they are single use only.
#4 ·
"Differential" or "rear end", "rear gear". Stock rear on yours is open rear, most likely 2.82. Stock SRT rear those years were 3.06 (3.09 is 2015+) and ALSO open rears and not only will you need to swap axles and hubs, but the back half of the driveshaft as well. As mentioned, a 2012-14 Getrag out of an SRT car gets you the 3.06, an actual mechanical limited slip and you don't need to futz with your driveshaft, just get the correct coupler. If you're interested (and maybe somewhat near MD) I have a full set 3.06 Getrag, axles and hubs that I was contemplating selling.
