Does anyone have a Mopar Performance SRT TCM, p/n P5155177, on an 08 300c SRT?
I bought one in june. It performed no different than a stock TCM. Stock shifts, and the Hold In Gear feature did not work. The car still up-shifted automatically in Autostick.
Has anyone else installed this and had it not work? All I want is the Hold In Gear feature.
This MTCM is advertised to work on 2005-2009 6.1's (as printed on the instruction sheet).
Definitely feel the difference in shifting performance when I installed one in my 08 SRT8, So much so that I'm thinking about getting rid of my Tranzformer. Is your C in fact an AWD SRT8?
When installed the MTCM on my 6.1, it was a night and day difference. If yours was purchased used, and you feel zero difference, I would suspect the programming was overwritten.
Doesn't make sense; the used one appears to be offering changes that can be felt (by your reckoning). It therefore should offer the same changes in the 08' as transmissions / functionality are the same.
The new one...who knows what was done with it while in FCA custody. I bought a new and installed it for someone...it too operated like stock. An exchange resulted in a properly functioning unit.
Note that with the SRT; the changes are not as significant as the RT version, given the SRT OEM TCM already has less baby sitting and the marked tendency to revert to longer shift events.
How precisely are you installing the TCMs into the 08'?
back my Trinity to stock tune ,run until the transmission temp is between 140f and 158f,after i disconnect the neg battery and swap the tcm for the MTCM reconnect the battery and proceed to the procedure 4-5 coast down from 5th to 4th gear and then 4th to 3 th gear.for the upshift adaptation temp must be between 140f to 212f .from a stop i moderately accelerate the car to obtain all gear range while keeping rpm below 1800 ,i do that 5-6 times
That will not work with a / any used TCM. Existing (stored - non-volatile) data needs to be purged using a StarSCAN / MOBILE / WiTech or other Diagnostic Tool.
I'll assume you already know and followed the following as specifically laid out in the Instructions; with a brand spanking new units, they are set up to automatically begin measuring and storing data. As temperature rises from one measuring threshold to the next, brand new TCMs commence storing the next version of specified parameters.
I was wondering about the exact procedure you used to ensure the new or used MOPAR Performance TCMs are not being overwritten with the stock TCM file that is stored in a / any hand-held when a tune has been loaded. This is usually the scenario that bricks MOPAR TCMs; returning to stock with the MOPAR TCM installed.
Related Threads
LX Forums Forum
5.2M posts
122.9K members
Since 2004
