Results 1 to 9 of 9
    Oct 2017
    Is a tcm needed with a stall converter?
    I’m having a issue when I floor the car from a dead stop it seems like I’m hitting the rev limiter it seems like it’s slowing me down I have bolt ons and a 3600 fti converter everything else is smooth just seems like it maybe it’s in the tune don’t know
    Jan 2016
    Are the tires slipping so badly that trans upshifts and slows you down?
    Mar 2016
    Whats the rpm flash too?
    Oct 2017
    That might be my problem
    Oct 2017
    I believe it’s flashing around 3800rpms
    Feb 2012
    Virginia, USA
    Use a (AJ) Hemituner TCM.
    I run a 3600 FTI behind my 392..use more of the Powerband. Start a savings account for rear tires and Mustang owner Is a tcm needed with a stall converter?
    Sent from my LG-M150 using Scat Pack Forums mobile app
    M11/ 392
    Likes von56 liked this post
    Oct 2017
    Ok thanks for the help I’ll give the hemituner tcm a try I appreciate the help I already have some tires lol
    Feb 2012
    Virginia, USA
    Quote Originally Posted by von56 View Post
    He will raise your shift points and work some other of his majikIs a tcm needed with a stall converter?
    Jul 2013
    Quote Originally Posted by 11R/TnBLK View Post
    I 2nd that. I had the exact same issue after doing a head and cam package with a 3200 converter. AJ's tcm cleared everything up. A must have for sure!
