Results 1 to 4 of 4
    Jan 2014
    options of axles for getrag lsd?
    Correct me if Im wrong. Need to know what are the options of half shaft axles for a getrag. So far I think its these
    Getrag axles
    Dss axles
    G force axles
    2011-2014 rt axles/ 2011-2014 srt axles?
    Is this correct?
    06 Black Mag R/T. Rear wiper delete, trunk handle delete, front and rear aluminum belly pans, Strut grills, Spectre drop in , straight pipes exhaust, 85mm Arrington throttle body, diablo sport Intune, Jet 180, billet catch can, st coilovers,spc adjustable upper control arms, BWoody endlinks, Petty's garage sways, speedlogix 4 point rear strut brace, Pettys garage front strut tower brace, long tubes, 2015 eagle intake, SLP Underdrive pulley, Getrag 3.91-axles/hubs, BMR rear suspension
    Jan 2011
    Calabash, NC
    i use stock srt axles and had no problems.
    PB 0-60 3.24 MIR Raceway Drag Radials 6/18
    PB 60' 1.472 @ CF9 4/18
    PB ET 1/8 6.911 @ CF9 4/18
    PB MPH 1/8 101.32 @ The Rock 4/19
    PB ET 10.857 @ CF9 4/18
    PB MPH 127.29 @ Atco 11/18
    Thanks PastorTree thanked for this post
    Calgary, Alberta
    Any Getrag 226mm differential OEM axles, be they RT or SRT, are the same units.
    Jan 2014
    Thanks guys
