Page 5 of 5 FirstFirst ... 345
Results 61 to 74 of 74
  1. #61
    May 2018
    SEC Country
    Quote Originally Posted by JD323 View Post
    I'm really not sure to be honest. I believe there is both Bosch and Siemens TCM's. I think the Siemens were the earlier build. I'll pull it out tomorrow and take some more pics of it.
    I just sent you PM.
  2. #62
    Aug 2016
    I have a 2006 300C SRT8 parts car. I'd be willing to send you the TCM if you'd like to swap yours out to rule that out. Just pay the shipping and send it back when you're done, or if it ends up fixing the issue, I'd sell it for $40. Here's a pic of it for part number reference.
    2006 SRT8 TCM 2006 SRT8 TCM - Album on Imgur
    That’s just awesome, and what this forum is truly about. Helping each other out
    GOOD LOOKING OUT TO JD323!!!
  3. #63
    Jan 2018
    Quote Originally Posted by gjdpk View Post
    I just sent you PM.
    Pm replied to.
  4. #64
    May 2018
    SEC Country
    A HUGE THANK YOU for the kindness give by JD323! Unfortunately that TCM did not change / fix my problem. That TCM worked, but worked just like my factory unit did; same issue remains.
    Very puzzling. It looks like I'll be making an appointment with a Dodge dealership to look at it and hopefully they are straight-up with me.
  5. #65
    Jan 2011
    Long Island, NY
    For sure you have to come back and post what the issue turns out to be.
    2005 Magnum R/T *sold* Now:2016 Challenger R/T Scat Pack M6 B5 Blue
  6. #66
    Apr 2012
    Altoona, Pa
    Yeah, this is why i don't do this ****.. haha This would be me for sure. Simple maintenance and bam, windows won't roll up.. haha
    20% window tint Custom Wrap Corsa Extreme Cat-Back exhaust Cooper Zeon RS3-G1 275/40r20
  7. #67
    May 2018
    SEC Country
    Rebuilt my valvebody. Fixed my issue.
    After a lot of logical troubleshooting, internet research, scouring forums, using the 9500 page LX Platform service manual for guidance, and part replacement, it turns out that rebuilding my valvebody was the fix.
    I pulled it out and broke it down to the base parts. Cleaned the parts with brake cleaner and compressed air. Then lubed up all the valves, springs, check balls, and screens with tranny fluid as I reinstalled everything. I also installed the Sonnax Overlap Control Valve Sleeve Kit and the Sonnax TCC Damper Valve Sleeve Kit. Got everything reinstalled. Worked like a charm.
  8. #68
    Calgary, Alberta
    Good job; what was root cause?
  9. #69
    Oct 2016
    Hey, go see the dealer.
    You'll spend more time and money chasing this thing down and maybe fouling things up in the process. If my experience any anything like normal, you'll bring it in, tell them what's misbehaving. The writer will tell you go into the lounge, have some coffee, read the paper a bit. When all is squared away, the writer will come back in, hand you the keys and your good to go.
  10. #70
    Nov 2014
    Quote Originally Posted by Santa Tom LaBelle View Post
    Yeah you keep believing that bud.
  11. #71
    Jan 2016
    Nicely done. I had a cop car with a Nag - stopped moving. No rev or drive. Our hotline said something was broke in gear train.I didnt believe that. Pulled apart and all was mint. Valve body fixed it. There are no pressure ports to measure pump output. They also told me to isolate the electrical side by starting it upand disconnecting the connector at trans. They said I should have 3rd gear default and manual reverse. Bull- I found out a nag needs electrical power to operate. There is no manual valve movement for hydrualics
  12. #72
    Aug 2016
    Sounds like a television show , and not reality tv:(
  13. #73
    Nov 2014
    changed transmission fluid, drove car, engine light came on and now in limp mode
    Yeah this is reality, you go to the dealer and tell them what it’s doing. They drive it and hook it to their computer, tell you they can’t replicate the issue, you go with them and point it out, they tell you it’s normal, they bill you for 150$ and you still have the same problem, you go home and come here and we tell you what to check, you go back to the dealer and suggest it to them, they tell you no it’s a different part, you opt to go ahead and replace the part they suggest and they bill you 600$, you drive home and the problem is still there, then you go back to the dealer and try unsuccessfully to get your money back, then you come here again and we figure it out together, then you replace the broken part for 100$ yourself and tell us your story about the stealership.
  14. #74
    Aug 2016
    Quote Originally Posted by BradJo9 View Post
    Textbook stealership right there !!! Right on the head...
