Page 4 of 4 FirstFirst ... 234
Results 46 to 53 of 53
  1. #46
    Feb 2019
    Southeast Michigan
    Quote Originally Posted by 91DakBuilder View Post
    I use the factory pink bolts with blue loctite. So far so good. Just put my factory driveshaft back in for a road trip. I’ll do the same method of blue loctite on the DSS shaft when I put it back in as well
    I think the "pink bolts" are for the older style cars though....the newer ones use a T50 torx bolt
    2018 Charger R/T
    Thanks 91DakBuilder thanked for this post
  2. #47
    Dec 2014
    Quote Originally Posted by snobrdrdan View Post
    You’re right I didn’t catch that I’ve got a 13 R/T. Not a 15+. That is terrible you have to deal with the Torx trash.
    13 Durango R/T
    13 M6 Challenger R/T
    02 M5 Dakota QC Sport
    91 TKO 600 Dakota CC
    63 Dart 3 on da Tree
  3. #48
    Feb 2019
    Southeast Michigan
    Big thank you to ronan978 for the DIY write up. You made it sound/look simple and convinced me to DIY it.
    I did it by myself, and I gotta say it was a little tricky trying to manhandle the diff and getting everything to line up while on my back (with the car on ramps).
    It's done but, again, it wasn't fun
    Here's another good write-up, btw, if you want to add it to the first post:
    https://static1.squarespace.com/static/58eed750d1758e9c1359a528/t/58f69446579fb3776b327ec7/1492554943722/TECH+ARTICLE+DIFFERENTIAL+REPLACEMENT+15+AND+UP.pd f
    And my driveshaft bolts were T50 torx heads
  4. #49
    Aug 2016
    Quote Originally Posted by MXS67454 View Post
    Great write up Ronan978 .. I've read your posts on results of your 3.70 swap and am not surprised at the lack of improvement.. you stated you believe the 3.70 is too much gear for the A8 and I submit it's not too much but the wrong gear for a stock or in your case a mildly modified 6.4 and here's why .. I used an online gear calculator over a year ago when deciding on a gear change for my A8 Scat. assuming an average trap speed of a stock 6.4 is around 113 mph . below are the rpm's crossing the stripe at the end of the 1/4 using different gear ratios.
    3.09 @ 113 mph in 5th gear = 5273 rpm
    3.70 @ 113 mph in 5th gear = 6315 rpm ( too high )
    3.70 @ 113 mph in 6th gear = 4895 rpm ( too low )
    3.90 @ 113 mph in 5th gear = 6656 rpm ( way too high )
    3.90 @ 113 mph in 6th gear = 5159 rpm
    too high or too low rpm and you lose acceleration.
    the 3.70 with close to stock hp is the wrong choice for the drag strip in 5th or 6th gear .(it could be a good choice for a high hp N/A or low hp F/I )
    also, look how close the finish line rpm is between the stock 3.09 in 5th gear is to the 3.90 is in 6th ...almost the same except the 3.90 accelerates faster . I gained .2 with my 3.90 swap.
    an N/A 6.4 with 3.90 and a cam that would go to 7k would be an interesting experiment.
    I'm trying to shine some light on why things turned out the way they did . not Sh*T on what you've done. hopefully I accomplished that...
    also have you looked into the Per4mance Development rear differential brace to fix your wheelhop ? I have one on my 700 whp Scat and it really tightens up the rear.. no hop period..
    Just wanted to touch on this a bit more :
    This weekend I decided to put the 3.70 back in the car. Now with ported heads , custom cam , and a 426 along with fbo. Any how , another thing relative to this gear is going to be tire size. I’m now running the 3.70 with a 305/40/18MT SS(27.6”) about an inch smaller than oem. With the stroker , cam , gear and tire , the car feels incredible and is almost always in its powerband. I haven’t run any numbers or tests yet , but damn it feels good.
    Back to the original post quoted: I feel the 3.70 could be an optimal choice depending on the tire size chosen. We can deviate all the way down to a 27” tire to bring it closer to the 3.90’s rpm at the line in 6th gear, or we can run a larger 29-30” and find what would probably be the happiest middle ground crossing at 6k in 5th. [for a stock/mild 392] My numbers will be different, but I’ll get back when I get a chance to do some runs.
    Likes MXS67454, punisher69 liked this post
  5. #50
    Sep 2018
    Will the challenger differential work as well? I'm looking at getting the 3.09 LSD for my 2018 300.
  6. #51
    Aug 2016
    Quote Originally Posted by 18Hemi300 View Post
    Yessir
  7. #52
    Sep 2018
    Cool. Thanks for the info Ronan!! Got in a huge debate on the 300 Facebook page because guys said the 300s are different. Luckily it's already been done by one guy. The axle shafts are smaller, but the spline that goes in the housing are the same size.
  8. #53
    Aug 2016
    No worries! My 3.70 came out of a hellcat challenger. But we’ve swapped a 3.09 ,3.70 , and a 3.90 into my buddy’s 5.7 multiple times with said axles.
