Results 1 to 4 of 4
    Feb 2015
    Nipomo Ca
    SRT setup question
    It’s time to rebuild the front of my 05 Maggy R/T. Noticed the last couple weeks there is some weird wear on the front tires, and as i gradually turn in to sweeping corners while driving to work on the freeway the whole front of the explodes into shaking which can only be settled down by straightening the steering wheel. My problem is what to buy. I currently have the shocks and struts off of a 2007 Charger SRT. But looking for new struts and shocks comes up with alot of options. Anybody know a safe route to go replacing my SRT shocks and struts with new replacements? And what would be a decent suspension kit for rebuilding the front without ordering everything separately. Thanks!!
    2005 Magnum R/T Bright Silver Metallic,Lower baffle mod,DS Intune,SRT Bilsteins/coils,..Dropped Valve..rebuild...6.1 springs,chain/tensioner,damper,ARP fasteners throughout,Sidewinder cam,Comp Cams pushrods,Tune by Johan,Taylor 8.2 shortys,Speedlogix catch can,BT Batwing and engine bling,BT pink thingy,Scat Pack wheels,245/45/20,RKSPORT Viper ACR hood,full Volant SS cat back,AFE Magnum Force CAI,R1 Concepts black slotted/drilled rotors F/B,ceramic pads,DC Strut tower brace,Bitchin pistol grip shifter
    1970 440 Pro Street Cuda
    1976 340 Pro Street Plymouth Arrow
    2006 Ram 2500 4x4 Cummins
    Oct 2011
    PGH
    If you like the SRT setup over R/T just get new Bilsteins and springs from Mopar? In case you don't want to search and wait to find used rake-offs of unknown mileage and abuse, Bilstein still sells the shocks individually as "B6 Performance" shock absorbers for the '05-10 LXs. I'm sure there're cheaper options for factory replacements but I have no experience with any.
    More importantly, I'd go to a quality alignment shop first to get it in spec and see what they have to say is shot. That way you're not just endlessly chasing random bits. And by quality shop I mean not the corporate repair facilities that just follow the computer and lasers, but one that can do custom alignments out of factory parameters (road racers and autocrossers in your area should have good recommendations).
    FURIOUS FUCHSIA 2010 Challenger R/T Classic A5
    WHOA RideTech coilovers, Hotchkis sways, PowerGrid endlinks, REM & Petty braces, CTP/BFNY bushings, AAD harness bar w/ Sabelt 6pts // SLOW SMF SRT 14.2 front & Pursuit BR9 13.8 rear rotors, Carbotech pads, Russell lines // FLOW LMI F-IV intake, Belanger Tri-Y headers, Zoomers catback, Joelvan's p/s pulley & dual-pass radiator, Russell p/s cooler // GO 215mm Wavetrac diff, AMG diff cooler & BlueTops, B&M pan, Tranzformer & NoESP // AERO 392 front clip // SHOW WebElectric, Hurst, Billet Tech, RiderGraphix, Performance Pedals
    Feb 2015
    Nipomo Ca
    Thanks TheFrankenberry, i appreciate the input. I was thinking that i just had to replace the struts and could
    keep the current springs? Or is better to replace the springs also. I think these had 35k when i instaled them and they were great for another 35k. Now the front just rattles and clunks and feels really loose.
    i noticed when i had a tire off a while back the UCA joint was shot. Then i forgot about it. Im guessing everything needs to be replaced now (180kmiles) but your right about having it checked out just to make sure. When i went to the dealer to ask about struts for a SRT they said since i didnt have a vin # there were a ton of options. I figured there would only be one for a SRT.
    Jun 2017
    Phoenix, AZ
    Quote Originally Posted by Little Red R/T View Post
    I just did something similar. I ordered strut assemblies and shocks for an SRT Magnum and put them in my R/T Magnum. I'm still running the R/T rear springs though. In my opinion, it's easier to swap the whole front assembly than to try and reuse the springs. It definitely changed the ride height a bit and the handling is much better!
    1949 International KB2 "Mater" 302/T5
    1968 Dodge Dart GTS "The Drat", 340/727
    2006 Dodge Magnum R/T the "Wagnum", 5.7/auto
    2016 Dodge Durango Limited, 3.6/auto
    Oh Drat! Racing
