Results 1 to 8 of 8
Thread: Need new TPMS
    Feb 2018
    Boca Raton, fl
    Need new TPMS
    One quit, gonna replace all four? 2013 300S Thanks in advance.
    Amazon.com : chrysler 300 tpms
    Lot of options, make a diff on which one?
    13 Chrysler 300S, Stock 17 RAM 6.4 BGE with TSP Stage 4 boosted Cam, AIT 18% OD pulley, E-force 2.62 pulley(12.2 lbs boost),, Fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, 3" Magnaflow Cat-back, FTI 2800 stall, Trans by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. aluminum rad. SRT fans. Brembo upgrade. Stage one MOPAR springs, XIX X39 22x9 +15 - 22x10.5 +22 with NITTO NT555 265/35R22 - 295/30R22
    Jun 2017
    Phoenix, AZ
    I just had discount tire replace mine while they had the tires apart. No idea what brand they used
    Sent from my Pixel 3 XL using Tapatalk
    1949 International KB2 "Mater" 302/T5
    1968 Dodge Dart GTS "The Drat", 340/727
    1972 Dodge D200, 318/727, soon 440/518
    2006 Dodge Magnum R/T the "Wagnum", 5.7/auto
    2016 Dodge Durango Limited, 3.6/auto
    Oh Drat! Racing
    Jun 2015
    Southern Connecticut
    The OEM unit for a 2013 should be 56029398AB, 433 mhz.
    "Many true sports cars can be outrun by a powerful sedan." - Sir William Lyons, Chairman, British Leyland
    Feb 2012
    Houston TX
    Replace all 4 or replace them as they quit, doesn't make much difference other than repeated trips to the tire shop.
    After a poor experience with several "supposed to work" brands that didn't, I went with OEM.
    Richard
    Mar 2016
    N. GA
    I installed HUF, German made, 433MHz onto new wheels. No issues. Put them in and Discount tire activated them free.
    Don't get dual MHz units, 315/433 lots of complaints out there.
    Apr 2020
    Ontario, Canada
    I used two sets of Dorman units. One set on an 06 300C and one set on an 07 300C. No programming necessary. Just install and drive and they self program after a few mins. Great, BUT, both sets appear to have weak signals or something because the TPMS warning still goes off and shows the pressures with one tire off, and then after a few minutes all tires read the same. Press the compass button to get back to my normal display. After a while the TPMS goes off again. Same scenario. Junk sensors? Probably. I will go with OEM next time.
    Feb 2008
    Pomona, CA
    Standard Motor Products #TPM17A (Rockauto) worked flawlessly in my 2007 Magnum after being quoted $400+ from the tire shop... I ended up doing it myself with these. They worked well - no problems or special programing needed other than taking a short drive. For the 2013 300, use SMP TPM#137.
    Mar 2016
    N. GA
    I was told and read just install and drive but the Huf's didn't, and speaking with the discount tire tech he said it's not 100%, some BCM/PCMs are stubborn and the car was looking for why all four of the previous sensors vanished.
    Huf is a known quality tps.
