Results 1 to 7 of 7
    Feb 2016
    LX wheel and tire fitment help 06 charger srt8
    Hey there guys! I am a newer member on the forum so first i will introduce myself.
    Hello! my name is Jake i'm located in Toronto, Canada. I drive a 2006 dodge charger srt8
    i'm getting my car out of storage in the next few weeks and shes getting some new shoes!
    i have my heart set on the following setup
    FAST WHEELS REPLIKA r179
    20x9.5 71.5 bore +18 offset
    20x11 71.5 bore +25 offset
    im trying to run cooper zeon rs3-s
    275/40r20
    305/35r20
    my question to you guys: will I have ok fitment with this setup? Or will there be rubbing?
    I would go 315 but the 305 offers a great price point.
    thank you for your advice
    p.s. I have stock ride height currently
    Feb 2016
    bump - I was told id possibly need a 3mm spacer in the rear to clear the inner liner.
    Mar 2017
    Bedford, Texas
    The fronts should clear fine, depending on the spoke design.
    In the rear, if it were me, I'd go for 3mm-6mm spacers. There are some that run +25mm offset with no issues. I have a 6mm spacer on my 20x10.5's with +25mm offset and 315/35's in the rear. I like the extra clearance inside.
    Feb 2018
    I just installed some Stance sf08 10.5x20x25mm and 9x20x20mm with 305/35/20 & 245/45/20 Cooper RS3-G1. I don't believe mine rub but I never saw any obvious rub marks but the liner was a cleaner black than the rest but then I also had rub those bumps with my fingers before installing them. The rim did not stick out past the fender without a tire installed but with tires on the rim mine did stick out past the fender just a little. The tire was very close to the dreaded bumps and I don't think I would do 11" on mine. I almost went for 11" but glad I didn't. I dropped mine a good 2" a week later and have been fooling with that and will get another look next weekend. I actually think I gained more space on the dreaded bumps after lowering it and of course my tires do not stick out with the negative camber created by the drop.
    Apr 2009
    Monroe Washington
    do you have any pics of your stance....looking to do 315's on my 06 Charger.
    Feb 2018
    I have a few but they're to large. Seems I'm not allowed to post a photo any larger than an ant!
    Feb 2018
    Microsoft services
    Microsoft services
    Microsoft services
    Microsoft services
    Microsoft services
    Hope these work correctly? I believe the rear has dropped a little more since these pictures. The right rear is adjusted as high as it can go and the left rear has about 1/4" left to go higher. it was a little higher even with the stock suspension. I'm working on making some spacers that will hopefully work and let me get her just a little higher, 3/8" - 1/2" higher in the rear. Negative camber is a little more than I want at least -2* and once mostly corrected with bushings I believe there will be major tire rub if even drivable on my streets. I think the fender will be almost right on top of the tire. I find it impossible to get a true height measurement because every place I try a measurement I get different readings. The best I can say is the right rear is at 28" to the top of the fender from the ground. Sometimes a little less and sometimes a little more. I don't believe there is a level flat place in my entire city including my driveway!
