Results 1 to 5 of 5
    Jun 2007
    Jackson, MS
    Aluminum sealant on center caps
    I recently got some new replacement wheels and my old BT center caps no longer fit. I had to grind down the caps to make them fit. After an embarrassing amount of hours on this, I’ve finally gotten them to fit while keeping the bolt holes intact.
    Do I need to seal the ground surface? It will not be visible, but I also don’t want to cause corrosion on my wheels. The wheels are painted, but I could have some scratches where these are installed. I think Billet technology uses AL6061. Any suggestions on sealing would be appreciated. I need something very thin.
    SCOTT57RT
    2007 RT Charger 5.7L - Black Crystal Pearl
    Mods: DiabloSport Predator - InertiaTuned, MagnaFlow CAT Back Exhaust, JBA High Flow Cats, JBA Headers, 185Tstat, 85mm CNC Throttle Body, 6psi-P1SC Procharger Supercharger, Blown Spartan Cam, 20x9 FR SRT8 Challenger Wheels/Nitto555G2, Mygig, BC Racing Coilovers, Willwood Brakes&Rotors, 3.06 Getrag
    Aug 2012
    iowa
    I would put something on it as bare alum on bare alum will oxidize
    Just brush on some clear on the edges
    Thanks SCOTT57RT thanked for this post
    Calgary, Alberta
    The aluminum has already oxidized, shortly after you stopped grinding...
    No need to do anything, especially up against another aluminum source.
    Jun 2007
    Jackson, MS
    I’d really like to leave them uncoated since I have no room at all, so this is great news....thanks for the reply. I’m not in a snowy area and my car is not a DD, so I don’t have to deal with road salt. If I were, do you think it would matter?
    Calgary, Alberta
    Quote Originally Posted by SCOTT57RT View Post
    Given where the caps reside (inner / shielded wheel area), typical air flow, I don't think environmental conditions will be an issue. The oxidation that quickly develops on raw aluminum alloy surface after abrading or machining process acts like a protective coating.
