Results 1 to 4 of 4
    Mar 2020
    Unhappy Blew up My Transmission
    So i blew my transmission up on my 2016 Challenger Scatpack. And was wondering if 2016 Charger RT automatic 8HP70 transmission would fit directly without any modifications or any problems?
    Jun 2019
    SoCal
    I wouldn't bother trying, they have different part numbers, I know someone local who is selling a 6.4 8hp70 for $700, dm me and ill send over the link.
    Aug 2016
    Yes , the 5.7 HP70 is exactly the same as the 6.4 . only thing different is the converter and shift programming so you would need a TCM tune . what happened to your trans ? it’s unusual to ‘blow up’. an HP trans . normally the clutch slippage is the first sign of a problem .
    Mar 2020
    Quote Originally Posted by MXS67454 View Post
    Its my fault, i was lining up next to someone doing 20 roll so i shift my gear to Neutral and revved my car to make it pop and shoots flames (i got Pcm and Tcm tune) and then he took off while i was revving so I shifted to Drive and smashed it, car shifted it self to 6, i tried to downshift real quick, it downshifted with sudden brake (by itself) i tried to shift it to neutral and shift it back to drive but it won’t move its like its on neutral it revs but it won’t move. I can put it on reverse and it moves without any issues. I tried the emergency thing next to the shifter and unplug the battery, pulled transmission fues and put it back but it won’t move on drive.I smelled a clutch smell like burning clutch, there was no smoke or leak just the smell. I know i was stupid doing all that but I think i learned My lesson.
