Does anyone know for sure how many teeth on a 2009 6.1 reluctor wheel? In the process of building a 6.1 based stroker, the Manley crank came with a 32t wheel. Not sure how many teeth on on my stock 6.1 crank in my 2009 Challenger SRT8.
58 teeth; I'll assume your 6.1 is still assembled. Simply remove the crankshaft position sensor, mark one tooth, turn the engine (socket on dampner bolt) and count the teeth.
I was thinking about doing that. From what I have found out, the 32t wheel has a gap with no teeth on opposite sides of the wheel, the 58t does not. That should make identification pretty easy.......
Update, I checked with Chrysler parts and the 08-09-10 6.1 cranks are all the same part number (they come with the reluctor wheel installed), plus the replacement long blocks are all the same part number for 08-10 6.1's. So it looks like only the 5.7's went to the 58T wheel in 09...…..
It'll be interesting to confirm once you get it apart...
Related Threads
LX Forums Forum
5.2M posts
123K members
Since 2004
