Originally Posted by
Hemissary
As ChuckWagon points out, alternator failure root cause is overwhelmingly bearing failure, not current output.
Current generation on these alternators is pretty well fool-proof. They are blindingly simple and robust design with no active internal electronics. Current output simply increases with rpm. The current output (duty cycle) is controlled by the PCM, based on ambient temp (as it relates to BATT charge capacity) and real-time loads.
Edit: as to observed voltage output; again, this is a function of the PCM control circuitry. 14.5V output is normal, especially as temperatures drop to zero or below and battery charge acceptance decreases (ability to accept current dwindles because cell internal resistance increases as temperature drops)...
