Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Calgary, Alberta
    Quote Originally Posted by BM_SRT View Post
    I don't think that is correct. The Trinity always had options for AC on and off and they always kick on at my set point of 194 F and my ac is nearly always on.
    It does; along with all DS OBDII units. You can alter the values but they have no effect.
    Another anomaly is the medium speed fan setting in either mode...does nothing.
  2. #17
    Feb 2018
    If I'm remembering correctly, old school T.S. for hwy speed run hot, [aside from collapsing lower hose], was a worn impeller on water pump...How many miles on it?
  3. #18
    Sep 2007
    Warren Mi.
    I've also seen cars with the radiator clogged with cotton wood. Ac condenser had a little on it but radiator covered.
  4. #19
    Sep 2010
    Well now that I’m in the process of tearing down the entire top side of the engine I decided to boil the tstat. Opened all the way right at 190.
    2006 300C SRT8, Mopar cold air intake, Magnaflow shorty headers, cats and exhaust. KW Variant 2 suspension, Pioneer head unit, 10" Infinity sub with custom built box in the trunk.
  5. #20
    Sep 2010
    Nothing I’ve done has solved the issue as of yet. Once I get the cam and top end all put back together and tune ill
    let you know the results.
  6. #21
    Sep 2010
    All the parts were worn (185000 miles) and just did it mostly as preventative. Yea I’m well aware of new parts fail, especially mopr, due to the fact that I’m a Chrysler service advisor. However, it’s not the t-stat. Did the boil test, more than incense, and it opened up all the way right at 180-190.
  7. #22
    Sep 2010
    Water pump was replaced and the original impeller had no wear.
  8. #23
    Sep 2010
    Radiator is new and has good flow.
  9. #24
    Sep 2010
    One last note, if the thermostat were the issue, wouldn’t it make sense that when I was running wirh NO thermostat that the problem would have disapated? Just a thought. I’m really beginning to suspect the radiator size just isn’t up to the job and maybe going to a fluiddyne 4 core. If that doesn’t do it, MOTHING will.
  10. #25
    Mar 2016
    N. GA
    Sounds lie a t-stat and if so you have some bad luck with them.
    I had one warning me the same as yours and eventually failed to open and got hot.
    They can loose the wax medium that expands and operated the opening motor. Here is a pic on the one that got me.
  11. #26
    Calgary, Alberta
    Quote Originally Posted by MADDOG11 View Post
    There was road course discussion years ago about the flow rate within the cooling system being so high that without a T-stat installed, coolant would not linger long enough within the radiator to be cooled sufficiently.
  12. #27
    Sep 2010
    Hmm....interesting. Well once I get the top end all back together I’ll report anything out of sorts and go from there.
  13. #28
    Aug 2019
    Missouri
    Well this was an interesting thread and have learn a lot about our cooling systems. However I’ve found my issue a little too late lol. It was the heater core hose assembly near the firewall. It must’ve gotten sliced when reinstalling my heads or from my wiper blade assembly. I know it sounds far fetched but it happened. It jumped timing so I had to rebuild again.
  14. #29
    Mar 2016
    N. GA
    Damn! FYI, those "T" fittings back there are notorious for cracking with any kind of long milage or time on them.
