Results 1 to 15 of 29
    Sep 2010
    Coolant temp rising but not overheating.
    So recently (ie in the last year) I'v replace the radiator, cooling fans, 180 thermostat and water pump due to a rising temp gauge but never overheated. With that being said the engine, when at idle, runs right about 195-200 degrees with the A/C is on at the hotest point of the day. Then when driving temp will run up to approx 224-226 when driving at hw speeds. No coolant in the oil and no visual leaks. Anyone else experiencing anything like this?
    2006 300C SRT8, 6.4L Arrington short block, Comp Cam,
    11-19 UPDATED lifters, Mopar cold air intake, Magnaflow shorty headers, cats and exhaust, KW Variant 2 suspension, Custom Grill, LED lightbar Behind grill (for idiots driving around w/their high beams on all the time),
    Pioneer head unit, 10" Infinity sub with custom built box in the trunk.
    Jul 2004
    City of Trees
    What temps (low, medium, high) do you have the engine cooling fans kicking in? In all three of my Hemi's, I run 190* stats, and have the fans set to come on at: Low=200*; medium=205*; high-210*. The highest I've ever seen any of them is 214*, even in ambient temps over 100* with the A/C on high.
    06 300CSRT8, Comp cammed, 85mm TB, HP/DS Tuners, 06 Jeep GCO and 05 Magnum RT (5.7's) both modded almost the same, MDS "ON" Lt, Fumoto Drain Valves, BT Catch Cans, SRT8 CAIs, AFE Filters, Sonnax Trans Line Press Booster, SC, DS and HP Tuners, Transgo Shift Kit, ARH Long Tube Hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvrs, SRT8 frt/rear bumpers, FRI Sidewinder Cams advanced (Jeep 6*/Maggie 10*), 6.1 valvetrain, SLP 25% UD Pulley, BBK and Arrington 90mm T-Bodies, SOS Ign Coils,TEA ported/milled heads w/new valve seats, SRT Reps.
    Jan 2016
    What thermostat is it? It may be not opening all the way and only shows up at high speed.
    Sep 2007
    Warren Mi.
    Check for a mushy lower rad hose.. Replace and add a spring to keep it from happening again.
    Likes OlGeezer2018 liked this post
    May 2017
    That’s not overheating. What is the highest it has gotten too? 226 is very normal. If you don’t tune the car for the 180 thermostat it will run the stock temps.
    How are you seeing these temps on an 06? The evic displays oil temp not coolant. I run an actual water temp gauge in my car and it drives (in Arizona summers) around 220. Higher with some pulls.
    If it is actually spiking higher, pull the thermostat and boil it in water and make sure it opens 100%. Easy thing first.
    Sep 2010
    No tuner installed at this point so I can't control fan temp actuation.
    Sep 2010
    Yea i thought of that and replaced it twice. Then i ran it w/o a thermostat for a cou;ple of days with same result.
    Sep 2010
    Bottom hose is good and has the spring in it.
    Sep 2010
    Doing the hold the 2 inside lower steering wheel control buttons down for approx 10 seconds allows the vehicle to go into a kinda vehicle info screen. From there you can see numerous things that are not available in the EVIC.
    Jan 2018
    Pueblo West, Colorado
    I'm having the same issues you are. I don't remember what my fan temps are set at, but mine normally runs between 190-196 when idling or it's cool out. When it's hot out and I'm cruising it runs at 208-218. My guess is that the thermostat isn't opening up all the way.
    Jul 2017
    I had the same issue and it was the thermostat.
    2012 300 SRT: SLP LM II exhaust, Underdrive Harmonic balancer, Tuned by Hemifever, 180° stat, LMI Tru CAI.
    I am silently correcting you're gramar and speling.
    Aug 2019
    Missouri
    Quote Originally Posted by MADDOG11 View Post
    Id hate to ask, but what was the problem? Did you fix it? I’m literally having the same issue.
    Calgary, Alberta
    Man, by the sounds of it a lot of parts were replaced that were not the issue.
    When A/C is activated, fan set points revert to OEM values, overriding any values that have been altered using a hand-held.
    New parts fail sometimes immediately - sometimes within the first few hundred kilometers; failure mode for T-stats is biased towards remaining at or near the close position. They can be erratic during partial failure, as whatever volume-to-wax might still be present might still open the unit partially - but at a significantly higher temperature.
    Nov 2013
    South Florida
    Quote Originally Posted by Biggmarvv View Post
    I had the same issue and it was the thermostat. It was a newer unit and must have become partially stuck closed. Temps were only slightly elevated at low speeds but once there was some load, temps rose to about 230.
    2006 300c SRT8
    PWR Ported Heads | HHP Stage 2R Cam | 3.91 Getrag | GTP Ported Intake Manifold | Kooks Longtubes | Corsa Sport / SRT Resonators | AMG 8 Piston Brake Calipers | Hemituner 6,800 TCM | BT Catch Can | LMI True CAI V2 | Tranzformer | MM 87mm TB | Johan Tuned | REM Adjustable Endlinks & Front/Rear Shock Braces | 33/22mm Front/Rear Sway Bars | Michelin Pilot Sport 4S 305/35/20 & 275/40/20 | 10" Widened Oem Wheels | LC-2 Wideband Analog Output to Trinity | Mishimoto Full Aluminum Radiator
    Nov 2013
    South Florida
    When A/C is activated, fan set points revert to OEM values, overriding any values that have been altered using a hand-held...
    I don't think that is correct. The Trinity always had options for AC on and off. The fans always kick on at my set point of 194 F and my ac is nearly always on.
