Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    May 2015
    Louisiana
    I flush with the garden hose then get my supply of many gallons of distilled and keep flushing to get the tap out, then drain as much out as I can again. Jack up the rear a little if you have to. Then pour your 2 gallons of straight coolant in the rad and save a little for the expansion tank, then top off with a little more distilled and that's about it. With a 14 or 15 quart system you'll end up about 50/50 maybe a little more but close enough.
    Sent from my SM-N920T using Tapatalk
  2. #17
    THanks
  3. #18
    Calgary, Alberta
    Quote Originally Posted by albow View Post
    Unless draining the block isn't too difficult (and if I understand right, it has some of those highly strippable NPT plugs to remove) I will but it sounds like not. THerefore, my plan is to drain, refill with water, drive until the tstat opens and repeat until clear. Also I have pure anti freeze, not 50/50.
    The block-based NPT plugs have HEX heads making them easy to R&R.
  4. #19
    Thanks for that info!
  5. #20
    Calgary, Alberta
    Did I tell ya its messy?
    Seriously, look carefully at the quality of the coolant that is initially coming out of the engine. Along with a really good inspection will dictate whether dropping the entire contents actually has merit.
