Page 12 of 12 FirstFirst ... 2101112
Results 166 to 167 of 167
Thread: It has begun
  1. #166
    Mar 2017
    Bedford, Texas
    It's the B&M 70298 because a wise man I know also used that one ;-)
    The thermostat is on at 175F. Based on the 15F variation on every other unit/ switch I looked at, I presume it's off @ 160F.
    If that's too cool, I do have an inline 195 on/ 180 off I can install and bypass the cooler's tstat, even though I don't want it that hot.
  2. #167
    Calgary, Alberta
    You so funeeee...
    Now I remember, it was the Derale unit that was 190F. In essence the HiTEK unit is mimicking the OEM set point @ 150F'
    Hoping for your sake - the TBV is actually root cause :^)
