Results 1 to 10 of 10
    Jacksonville, FL
    Long Tube Headers and False Knock
    Have any of you that installed long tube headers discovered that the your car picked up a false knock signal which retards timing, and thus restricts power?
    I'd like to install long tubes and run a before and after dyno to monitor the amount of torque and horsepower that they increased. I had just did that with a LMI 392 True CAI.
    After the upgrade of intake and headers without a tune, then I wanted to see how much a tune would help.
    Terry
    2019 Octane Red Charger GT
    2020 Charger Scat Pack Widebody
    Nov 2010
    Yes I have false knock with Lt headers on a 6.1. And yes I did a before and after with the lmi but not on the Dyno at the track and picked up 3/10. My time slips are in his Facebook page
    The lmi true cold air is no joke. It works
    Mar 2016
    DE
    Turn off the knock sensors and runs the test passes.
    Nov 2010
    I left the sensors turned on. AJ said there’s no harm in it. It’s a street car so I don’t care
    Jacksonville, FL
    Quote Originally Posted by Renfrick1 View Post
    sent from my iPhone using Tapatalk
    Let me try to get some clarity on the above posts:
    1. Is it safe to say that both of you have a tune? Isn't that how it is possible to turn the knock sensors on/off?
    2. If the knock sensors detect the knock, whether it is an actual knock or a false knock, doesn't the computer pull the timing, and thus lose power?
    Central Florida
    The knock sensors can have their sensitivity altered without turning them completely off. CMR tune required.
    Old 426 guy,
    Jim
    Mar 2016
    DE
    Quote Originally Posted by RT NOMAD View Post
    Yes the knock sensor will pull timing (and lose power) if it correctly or falsely picks up a knock.
    I dont see the need for them.
    Nov 2010
    Yes I have a blower and tune. I left them on for safety. I’m not out to break records. I trust AJ ‘s tune but like I said. I’m out having fun. I don’t care if it pulls timing
    Jan 2011
    Calabash, NC
    That explains it!
    PB 0-60 3.24 MIR Raceway Drag Radials 6/18
    PB 60' 1.472 @ CF9 4/18
    PB ET 1/8 6.911 @ CF9 4/18
    PB MPH 1/8 101.32 @ The Rock 4/19
    PB ET 10.857 @ CF9 4/18
    PB MPH 127.29 @ Atco 11/18
    Nov 2010
    Let’s race !!
