Results 1 to 8 of 8
    Mar 2019
    West Hollywood, CA
    Brake squeal... advice/help!
    Hey guys... I just hit 3K miles on my 2019 Charger Scat Pack and every day after about 10 minutes of driving, my brakes squeal every time I come to a stop. Doesn't matter what "mode" that I'm in either. It's VERY annoying.
    Is this "normal?" Something I should have the dealer look at? I've never had a car do this... but I've also never had Brembo's either.
    Thanks!
    2019 Dodge Charger Scat Pack
    Mar 2017
    Bedford, Texas
    It's normal for these brakes. It's the only downside to the Brembos....they squeak.
    A few others have changed to Power Stop pads to keep the dust down, but idk if they still squeak or not.
    Nov 2015
    Eastern NC
    Yep my Camaro with factory Brembos squealed too, sometimes worse than my SP. I believe the Powerstops do help with it. Heat00 can probably confirm.
    Previous:
    '17 Camaro 2SS A8
    Oct 2018
    As other said, new “quiet” pads. Otherwise, as long as you’re not getting poor performance or vibration, completely normal.
    My advice? Your exhaust is too quiet Brake squeal... advice/help!
    Feb 2019
    Mine squealed like crazy from day 1 . Thought it was front but after changing fronts still made noise. Replaced rears and it was gone. I went with Akebono pads from Rockauto. Pretty much zero dust, no noise and no difference in braking to me. ASP1053 and ASP1149 were the part numbers.
    Nov 2013
    South Florida
    Its not normal from experience. I have run 2, 4, 6, and 8 piston Brembo setups over the vears and not one had a squeal that I could not remedy.
    It's either due to:
    1. Poor amount of lubrication on the back of the pad/shim (I use CRC Silaramic on the back of the pad, shim and on the hardware)
    2. Pad compound. I use StopTech street performance up front and Akebono in the rear. With all other variables the same, some pads squeal and others do not.
    3. Sometimes a good bedding can take care of it.
    Sometimes it's the combination of the pad and rotor that just produces the harmonic and there's nothing you can do other than try another combination. For example, the Akebono mentioned above cause an incurable squeal on the front brakes but were silent in the rears. I went through 3 sets of pads to figure that one out. Once I replace the OEM rotors with an aftermarket option, I'll bet one of those previously squealing pads will be silent.
    2006 300c SRT8
    PWR Ported Heads | HHP Stage 2R Cam | 3.91 Getrag | GTP Ported Intake Manifold | Kooks Longtubes | Corsa Sport / SRT Resonators | AMG 8 Piston Brake Calipers | Hemituner 6,800 TCM | BT Catch Can | LMI True CAI V2 | Tranzformer | MM 87mm TB | Johan Tuned | REM Adjustable Endlinks & Front/Rear Shock Braces | 33/22mm Front/Rear Sway Bars | Michelin Pilot Sport 4S 305/35/20 & 275/40/20 | 10" Widened Oem Wheels | LC-2 Wideband Analog Output to Trinity | Mishimoto Full Aluminum Radiator
    Calgary, Alberta
    Jul 2010
    Toronto, Ontario
    Thumbs up
    Just to throw more stuff into the mix; I just replaced my rear brake pads with OEM Brembo pads Brembo brake pads 2010 Challenger SRT8
    And low & behold the squeaking (that I had since the SRT was a year old (2011) is now gone !
    I had initially thought the squeal/squeak was coming from the front, so when I had to replace
    the front pads in 2017, I replaced them with Hawk HPS pads, and even with proper bedding,
    the noise was still there. Back to 2019, by just replacing the rear pads with OEM Brembo pads
    and having them properly bedded, plus using the pad lube that came with the kit, the noise
    is now gone, woohoo !!!
    Allelujah !
