Fuel pump for force induction
19K views 11 replies 10 participants last post by  fastrt09
#1 ·
I have ordered a Wipple supercharger kit for the SRT and expect to receive within 3 weeks. Anyways I'm not very comfortable running it with the 100K miles original fuel pump. Although it comes with an MSD pump booster, i think replacing to a new higher capacity/pressure is not a bad idea. Was looking at the Walbo 450 or 525 pumps and was wondering who sells these with the installation kit for this car including the hard wire kit. Another option is to use a 6.4 pump which looks like a direct replacement for the stock unit and is of higher flow.
#3 ·
The A2speed drop in is what I use on my nitrous car. It ups the flowing fuel pressure to 62psi and is supposedly good up to 700rwhp. It is a very easy install as it is not a return setup, two wires to connect and done. If you plan on being at or over the 700 hp mark, look into a return style setup. Then you are talking big money for a fuel system though.
#4 ·
I run the same pump as the other guys. Easy install, and pretty quite too.
#7 ·
Yeah the A2Speed worked well when I did the original Whipple install on my 300
