04 Ram 1500 blend door issue
My 04 Ram heater only blows cold air. I've YouTubed the issue and see what could be the problem. If that door is screwed shut stopping outside air from coming in, will that work?
depends on the actual issue. If the blend door is broken, I believe that door is deep in the box and requires the box to be removed.
- You may not post replies
- You may not edit your posts
Forum Rules
