Modern Mopar Performance Group
Results 1 to 1 of 1
    Jun 2008
    Martinsville
    LMI Hellcat Cold Air Intakes In Stock!
    https://www.modernmuscleperformance....ke-by-legmaker
    Modern Muscle is proud to offer the Legmaker Intakes brand of high quality carbon fiber cold air intakes for the Dodge Hellcat platform. LMI (LegMaker Intakes, LLC) specializes in REAL CARBON FIBER cold air intakes of various designs and applications. What separates LMI from the million other intake offerings to choose from is performance, price point, quality, and most of all the unique fabrication process that allows the carbon fiber intake tubes to have smooth finishes inside AND out!!! No other CF intakes are made like these!! All intakes are made in-house.
    Features:
    • Independently tested 18-22 rwhp increase over stock airbox (Tests conducted by DiabloSport, LLC)
    • Handmade from 100% real carbon fiber construction for superior heat characteristics
    • Proprietary fabrication process resulting in a smooth inner surface to ensure optimal air flow
    • "Funnel" shape of 6" opening smoothly transitioning to 4.5" to help speed airflow and decrease restriction
    • Large 6" diameter S&B filter with 8 layer protection (oil type)
    • High quality silicon coupler ensuring smooth transition to throttle body
    • High quality stainless T-bolt clamps provided
    • Drilled for IAT/Oil breather fitting with a rubber grommet for secure fit and seal
    • Billet aluminum MAF flange for proper sensor performance and fit
    • Laser cut rain shield with superior wrinkle finish powder coat and machined Legmaker logo
    • AFE water repellent pre-filter to ensure maximum protection of filter from moisture and debris
    • All necessary hardware and instructions for DIY install
    • ZERO cutting or modifications needed to install
