Modern Mopar Performance Group
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Jul 2009
    Edmonton, Alberta
    Are they worth it for non boost engines. What have you seen for high c.I. na engines?
    09 HO Superbee #391 - Arrington built, 461c.i. Aluminum block, Paramount Stage3 Transmission and 3400 Torque converter, all installed by Authentic Performance. Tuned by A.J., Modern Hemi 2 Step Launch Control, More to come.
    All old engine Best,
    0-100=5.3, Reaction=.000, 60'=1.988, 1/4=12.989, MPH=108.73, 9L/100KM, 270KM/H
    2013 - Dodge Dart SE Euro, the new winter beater
    1998 - Dodge Dakota - sold
    http://www.dragtimes.com/Dodge-Charg...lip-27967.html
  2. #17
    Jun 2008
    Martinsville
    Quote Originally Posted by SPRBEE View Post
    We have only used these on boosted motors so far, what heads are you using now?
  3. #18
    Jul 2009
    Edmonton, Alberta
    Ported 6.1 I do believe.
  4. #19
    Apr 2016
    Fort Rucker, AL
    S these are new hellcat heads that you rework, so that being said putting these on a 6.1 you can install the hellcat blower as well correct?
    Thanks agoristmike thanked for this post
  5. #20
    May 2013
    Quote Originally Posted by BradMagRT View Post
    In theory yes, the physical blower will bolt to the top of the motor. But to get the belt drive to line all up, you will need to purchase the revised timing cover, crank damper, tensioners, etc. Worst part will be trying to tune the electric bypass valve that is equipped in the hellcat blower, it is not mechanical and run by the ECU, older 2015 and below, don't have the ability. If you figure it out, plan on a new engine harness, as well.
    New Setup: 2014 300 SRT8...Build Thread Here http://www.lxforums.com/board/genera...ml#post5038885
    2006 300C SRT8 (sold): Whipple 2.9, HHP 426, 740whp/680wtq on pump, Best ET 10.74 @ 131.8; 835whp/762wtq with meth+MS109, Best ET 9.84 @ 139
