Results 1 to 4 of 4
    Oct 2004
    Lantana, FL
    Magnum Sheet Metal Question
    Does anyone know what kind of metal the Magnums are made from and its thickness gauge? I'm trying to do some welding on mine and it just keeps punching holes through it. I've set the welder to the lowest setting and it still just punches holes through it.
    Mods --> Shaved door handles, shaved rear 1/4 windows, shaved gas door, shaved bumper grooves, shaved liftgate wiper and handle w/ relocated open switch, 2-door conversion.
    To Do --> Low profile mirrors, shaved tail lights and then flush mounting them to the lift gate,
    custom paint.
    Mar 2016
    DE
    My guess would be 18gauge.
    And I guessing your using mig,
    What size wire?
    Try using a copper backing plate.
    Oct 2004
    Lantana, FL
    I'm using .030 wire. I don't think it's 18 gauge. I'm using 18 gauge to weld to it and it's doing fine, but the body metal is melting away.
    Mar 2016
    DE
    True, I had older stuff on my mind. Newer cars are more 22 gauge.
    030 wire is to heavy, that’s max for 18gauge.
    I would be down in the .023 range.
    Only spot welding here, and use a backing/cooling bar as much as possible.
