Results 1 to 9 of 9
    Apr 2015
    2006 msrt jump post cap/cover
    I can find the curved charger caps all day but the straight caps for the magnum are unicorns it appears
    Anyone have any leads? Its the red cap passenger side on the jump posts.
    Feb 2019
    Southeast Michigan
    Someone recommended a newer part, 68188999AA, but according to this post it doesn't fit right...just FYI:
    2006 Jumpstart Post Cover?
    2020 Charger Scat Pack
    Apr 2015
    Yeah thats the curved version mopar part #68188999AA
    Really I just want the cap so its red and not pinkish and also that post should be covered just in case
    Parts are starting to get thin. I'm building mine back cosmetically before we get into the engine.
    Sep 2018
    Springfield, MO
    If you have one on there, a brief 400 grit sanding and spray paint will suffice a part that resides behind the wheel well cover
    If you mean the one in the engine bay, same thing. Neither gets that hot or exposed to a beating.
    Likes snobrdrdan, Hemissary liked this post
    Calgary, Alberta
    Given they are integral to the FCM assembly, to get the color (non-oxidized) you would need to locate a new assembly.
    As Ultimagic5 suggests; if you still have the cap, paint it, call it a day. Or get creative, make your own...
    Note: because the cap depends on a live hinge the utilizes the plastic the unit is extruded from, ultimately its going to fail (wrong type of plastic for a live hinge). YOu can make a new hinge using GOOP. Its an awesome adhesive that will work as a hinge for some time - maybe forever if you're not constantly opening / closing it...
    Jul 2014
    Calgary, Alberta
    ​Great find; thanks.
    Apr 2015
    Need the 3d printer people to get to work! Lol
    Hey are your covers all hydro dipped and clear coated over? I wrapped mine with 3m di-noc but its a much more matte appearance compared to yours.
    Looking like I'm gonna be painting and or dipping soon cuz these don't exist.
    Calgary, Alberta
    Quote Originally Posted by Spandy View Post
    Yes, they are.
