Results 1 to 4 of 4
    Jan 2019
    Long Island NY
    Headlamp Assembly Hardware
    The left headlight is a bit wobbly. I thought it was a broken tab, but there is a small bulb shaped pin on the rear outer edge that fits into a hole in sheet metal. The hole has a plastic retainer to grip the pin. The plastic retainer part is broken, and I don't even know what it's called. Suggestions? Links? Thanks!
    Calgary, Alberta
    I'll guess...I guess...
    Retainer 04806111AA, ball stud (receptacle), headlamp to fender
    Thanks Johnsand thanked for this post
    Jan 2019
    Long Island NY
    Ebay thinks it doesn't fit a Magnum. I think if it fits a Charger, it will fit a Magnum. Thanks!
    Calgary, Alberta
    Quote Originally Posted by Johnsand View Post
    You still haven't stated what year...
    For 05'-08, yes, the retainers are all the same PN...
