Results 1 to 14 of 14
    Feb 2009
    Hernando,MS
    HELP!!!! No exhaust passenger side tail pipe
    I have an odd problem. I have an 07 magnum r/t that I have had the motor built. Has a 392 stroker kit from Scat, big cam, eldelbrock heads, edelbrock victor jr intake. This morning as I got on the interstate, it started running really bad. I limped it home and as far as can tell it is only running on 4 cylinders. I am getting no exhaust from passenger side pipe. Checked spark plugs and they are wet with gas. I swapped all 4 coil packs from driver side to passenger side and same problem, no exhaust on passenger side. It runs no different when I unplug all 4 coil packs on passenger side. It's as they they aren't being told to fire. I am getting no codes shown on my diablo tuner, except when I unplug the coil packs. Any ideas?
    Sep 2018
    Springfield, MO
    I wouldn't worry about it...if you have a dual exhaust the system will do what it needs to expel gases unless there's some sort of damage on that side
    Feb 2009
    Hernando,MS
    Quote Originally Posted by Ultimagic5 View Post
    It's running terrible. Passenger side headers aren't getting hot either. Something is definitely wrong, just don't know what.
    Feb 2009
    Hernando,MS
    I have been working on tuning it and have about 1500 miles since motor put in the car. Is it possibly rings washed out?
    Mar 2016
    DE
    hrmm. Sounds like a possible ground issue. but i would think it would throw a code for that if it codes for unplugging the coils.
    Washed cylinders will still fire and make some heat. It will have excessive crankcase pressure though with washed cylinders, so thats an easy test to see.
    Compression test would be a easy test too.
    Have you swapped fuel injectors around?
    Whats the afr reading?
    Feb 2009
    Hernando,MS
    I've given up for the night. I think the injectors ate fine because the spark plugs were wet. My tuner is coming by tomorrow and we will check the afr reading. Hopefully something shows up on his laptop.
    Thanks for the suggestions!
    Feb 2018
    I'd check compression on that bad side....May have out of time cam to crank.....plugs can stay wet from lack of compression...Good luck
    Jan 2016
    The passenger side wiring harness are known to melt together on our early LXs.
    Sep 2013
    Falls of Rough, KY (Rough River Lake)
    It's an electrical issue - either the wiring has an issue, or the computer is bad. If you check the coil packs, I'm pretty sure they are not getting an electrical impulse to fire.
    Feb 2009
    Hernando,MS
    Quote Originally Posted by RDT View Post
    Even if when I unplug them, it shows a code for each coil pack?
    Feb 2009
    Hernando,MS
    Figured it out. Catalytic converter had come apart and plugged the exhaust. Brand new kooks that came with my headers. Went ahead and knocked out the driver's side too. Now to get the tuning right and let this beast out.
    Thanks everyone!
    Thanks coanan thanked for this post
    Mar 2016
    DE
    Very interesting. Good find!
    And thanks for posting the fix
    Feb 2018
    yes...thnx for posting the find...Amazing to me....I thought komputers were smart...! Why did they allow pumping more and more fuel in, soaking the plugs, when 02 sensors must have been reporting No exhaust flow..!
    Feb 2009
    Hernando,MS
    Quote Originally Posted by OlGeezer2018 View Post
    My tuner had the O2 sensors off.😕
