Results 1 to 4 of 4
Thread: Something odd
    Nov 2019
    Something odd
    05 magnum rt
    Got a p0700
    There is a leak that I'm waiting for parts. When fluid is low it doesn't shift. But when I add fluid tranny is normal...could the code be for the leak?
    Sent from my GM1915 using Tapatalk
    Dec 2016
    Charlotte NC
    P0700 is a generic error code that just says "hey you got a problem". There should be another code(s) hiding behind it. But you may not be able to read it without the proper scanner. But in a nut shell if you are leaking transmission fluid resulting in a no shift situation then YES that should answer your own question.
    [/SIGPIC]2005 Chrysler 300C SBE, ported big valved heads, Hellcat lifters, SRT 6.1 intake manifold, SRT shorties, custom grind Billy Drakeford cam, SLP LM1, MTCM and GETRAG 3.06 swap.
    Likes sin.hemi57 liked this post
    Nov 2019
    Quote Originally Posted by 4DoorMuscle View Post
    Would low fluid trigger that code?
    Feb 2017
    Orange County, CA
    It sounds like low fluid is the cause...but that likely means you have a crack/leak or are running hot and burning through fluid. Both are bad.
    Get a code reader and see if there are other codes too.
    2006 Dodge Magnum SRT8 // silver // 58k miles // Mopar intake // muffler delete // Trufiber hood with carbon fiber overlay // 22" Viper Repro wheels // Bilstein // 265/35-R22 & 295/30-R22 Pirelli Scorpion Zero // 12" CVX sub // iSimple and iPod Nano 6th Gen // 20% tint all around // Touchscreen rearview mirror (backup cam + both f/r dash cams) // Fuelly MPG here
