Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    Nov 2014
    It’s dark and rainy now, I plan to trouble shoot tomorrow. It’s a two wire coil right? Just run one to 12v and the other to ground correct?
  2. #17
    Nov 2014
    Didn’t have the connector fully seatedA/C clutch replacement I’m the king of stupid town sometimes lol
  3. #18
    Mar 2016
    DE
    Well at least that’s an easy fix.
  4. #19
    Jun 2019
    i bought the kit before realizing WHERE Dodge put the compressor. (GM puts them right on top, knowing you'll go through 3 or 4
    Is there anyway this can be done with the compressor on the car? I don't want to waste my freon (is that still a thing) when all i need is a bearing...
    thanks!
  5. #20
    Jan 2008
    Aurora, Ohio
    Why is that snap ring beveled in the first place?
    Sent from my SM-N950U using Tapatalk
    05' Magnum R/T HEMI Registry #889 CAI, JBA Ceramic shorties-CATless, MTCM, Predator , MDS, ESP, 3.06 Getrag swap, HALOS
    Aus liebe zum Automobile "Out of Love for the Automobile"
  6. #21
    Calgary, Alberta
    Quote Originally Posted by CURLY View Post
    They are stamped parts; makes no difference which face is in or out, although the bevel might assist in some way during re-insertion.
  7. #22
    Jan 2008
    Aurora, Ohio
    Thx. Hemmisary! I finally got around 2 putting the air conditioner clutch, pully and coil back together. Then in order to torque the center bolt I turn the air conditioner on to engage it to the pulley and it doesn't work. Now I have to check circuits and fuses.
  8. #23
    Jan 2017
    Florida
    I understand that the orientation does matter, i.e. flat side on the flat bearing surface, and the rounded side towards you. Putting the flat side in keeps the snap ring correctly aligned to the machined groove that holds the unit in place.
    Dana
    2006 Dodge Magnum R/T (engine rebuilt and cammed at 102K 02/18 due to dropped valve seat flaw)
    2010 Camaro SS
    (Transformers Edition)
    1981 DeLorean DMC-12
  9. #24
    Calgary, Alberta
    Quote Originally Posted by DMC-81 View Post
    Nope; its a concentric part.
  10. #25
    Jan 2017
    Florida
    Hmm. Maybe the snap ring is different than on Sanden units, which have a flat side and a rounded/curved side. Therefore you can't correctly install them in the wrong orientation. I assumed they were the same because in Step 1 of the Installation section from the Service and Repair manual I linked to above it states:
    "The snap ring must be fully and properly seated in the groove or it will vibrate out, resulting in a clutch failure and severe damage to the A/C compressor. NOTE: A new snap ring must be used to secure the compressor clutch field coil to the A/C compressor. The bevel side of the snap ring must face outward and both snap ring eyelets must be oriented to the right or to the left of the field coil dowel pin location on the A/C compressor."
    However, I haven't rebuilt a Denso compressor to say for sure. I'll look at my old Denso compressor and see. A picture from the OP would help.
    Cheers,
  11. #26
    Jan 2008
    Aurora, Ohio
    Now that it's in is there a way to test the engagement or action before I put the supercharger up above it. When I turn the key on and activate the switch I get no action does it have to be running for it to engage?
  12. #27
    Nov 2014
    You can jump the relay pins and check that the coil pulls in
  13. #28
    Jan 2008
    Aurora, Ohio
    I was going to try that and figure it's a straight 12volts. But can polarity be reversed safely?
