Results 1 to 13 of 13
    Apr 2019
    O2 low voltage heater codes all four - 06 Magnum
    I did the headlight test for voltage and got
    No light when hooked up to heater pos and neg
    No light when hooked up to heater pos and remote ground
    Lights up with pos to remote 12v, neg to heater neg
    I checked the voltage coming from the PCM and got (3.64) volts
    I checked the grounds and had (0.00) ohms resistance
    Is it time for a new PCM?
    Calgary, Alberta
    Headlight test?
    Doesn't sound like the Diagnostic Test outlined in the Factory Service Manual...
    Apr 2019
    Yeah, no, I was referenced to this site from Craigslist forum for some better answers but I saw it referenced a few times on Youtube also that you use a headlight bulb to check for heater voltage because they they both draw similar currents and if there is no load on it, the ECM is expecting a load and isn't receiving one, so it reduces the voltage to the heater.
    So using this method I got the readings listed. It seems that the voltage is constant at 3.64v, which doesn't light the light or heat the heater. I originally thought there was a common ground or something that was causing all four to be bad but, I was getting 0.0 resistance on three of the grounds.
    Calgary, Alberta
    Follow the Diagnostic Process outlined in the Factory Service Manuals we all have the luxury of downloading for free.
    Feb 2017
    glendale az
    Quote Originally Posted by jawin_jonn View Post
    It is definitely time for a new pcm . The older ngc3/4 controllers were notorious for that problem, the 02 sensor heaters were a high side driver output coming out of the pcm. Most of the time when they fail they set codes for all 4 heaters at once, some rare occasions they will set only one or 2 .
    Thanks jawin_jonn thanked for this post
    Likes Rockhound liked this post
    Jan 2016
    Did you get o2 heater codes on all four. Two upstream have common ground. Two rear have common ground. As stated above Hi side driver for o2 heaters. I always check ground with high amp test light. An ohm meter wont check for load check.
    Aug 2016
    LINY
    Quote Originally Posted by circ1977 View Post
    So all four codes went on my 06 magnum plus a p1129 &1128 , I've replaced the sensors and the map to no avail. I'm starting to think my pcm is a possible culprit. Any thoughts ?
    Sent from my SM-G988U using Tapatalk
    16’ charger Scatpack
    Forged 392 based 426 stroker, Arrington phase four Apache heads, custom grind cam , ported and matched 6.1 manifold, long tube headers , solo performance cutback ,ati pulley and pinned crank , custom cai , Tba diff brace with 3.70’s out back and 30” et r’s
    Mar 2017
    Bedford, Texas
    By chance did you drop a 180 in there?
    Aug 2016
    LINY
    No sir , the only work I've done so far is body/chassis and suspension. And now the 02's and the map. I'm saving the fun stuff for when I get her running tip top.
    Apr 2019
    I sent my PCM into ZKboys, after seeing them on Youtube. They went through, checked it out and fixed the O2 heaters grounds. I had other issues come up after reinstalling it but, it had nothing to do with what they fixed.
    Aug 2016
    LINY
    What did they charge you ?
    Apr 2019
    $90
    It cost me $90 and I saw them on Ebay. You send yours in and they fix it, if they can.
    I think if they test it and it can't be fixed, they charge you half price for the testing.
    They say fast turnaround but, they might need a reminder
    SIA Electronics is a leader in the automotive electronics re-manufacturing field. With over 20 years in this business we have the knowledge and equipment to rebuild any automotive electronic part. ECU, ECM, PCM specialists.
    If your SKIM (security key immobilizer module) ever shuts your car down look up these people, they will send you a new PCM with the SKIM disconnected, so it will start with just a steel key
    Good Luck!
    All Computer Resources
    Feb 18, 9:49 AM EST
    Hello,
    Thank you for your interest in our products. Please provide a name, phone number, and a preferred time to be reached so one of our sales representatives may contact you.
    Sincerely,
    Thanks ronan978 thanked for this post
    Feb 2017
    glendale az
    yup, send in your pcm or get a replacement
