Results 1 to 8 of 8
    Nov 2015
    will wheel and tire combo fit?
    I have a local guy selling 20in verde 20x7 1/2 tires are 245/40 I hhave an sxt magnum with stock brake system.
    Black 2007 SXT
    Sep 2018
    SF Bay Area
    I don't know how different the SXT is from the RT, but I put 20s with 245/45/20 tires on my rt and I needed 3mm wheel spacers otherwise it rubbed (just barely). Stock tires were 225/60/18. Car is stock height with stock brakes. Hope this helps.
    Nov 2015
    thanks buddy
    May 2010
    MD
    Quote Originally Posted by ChoochG View Post
    Caveat though, you put on SRT 20x9's, stock R/T style 20x8's will fit an SXT no problem.
    03 Hemi Ram, 05 Magnum R/T, 06 Charger R/T (RIP)
    Likes CarDriver liked this post
    Sep 2018
    SF Bay Area
    Quote Originally Posted by HemiLonestar View Post
    True!
    Sep 2018
    SF Bay Area
    ...although I had stock 18" RT wheels and went to 20" SRT wheels
    Jul 2018
    You need to know your wheel offset. I went through this while searching for a custom wheel set for my RT AWD. AWD cars need wheels with a high positive offset of +32mm to +42mm. Non-AWD cars take wheels with less positive offset, in the range of +20mm.
    You can technically fit non-AWD wheels on an AWD car, but they'll stick out past the wheelwells and look goofy, or even rub the fenders. You CANNOT fit AWD offset wheels on a non-AWD car, however; the inner rims will probably obstruct with the brake calipers.
    EDIT: I should mention my summer wheels are 20 x 8.5", +40mm offset, but for winter, I'm using stock Chrysler 300 steelies that I believe are 18 x 8", +20mm offset. They stick out a bit from the wheelwells, but no rubbing issues...I'm fine with that for winter.
    Nov 2015
    all good they fit!!!!
