Results 1 to 9 of 9
Thread: Help! help!
    Jan 2017
    Help! help!
    Does anyone know how many liters of brake fluid does a Grand Cherokee srt8 2008 carry?
    Sent from my iPhone
    Brooklyn, N.Y.
    Did you lose/drain all of the fluid from the system or planning to flush for new fluid? Do you have a leak or is the fluid just reading a bit low? If reading a bit low with no leaks could just be time for a pad change.
    Just mentioning some items to help you get info.
    15 Grand Cherokee SRT: Staying Stock!!!
    05 Magnum RT:
    5.7 Personal Best: Heads, Cam and Spray - 11.46 w 1.59 60'
    6.1 Personal Best: Forged, Novi 1500 and Spray - 10.405 1.566 60' @ 129.69
    7.4 Personal Best: Aluminum 449 - 10.736 ET , 1.589 60', 125.05 MPH NA
    7.0 Personal Best: Iron 426 - Whipple 2.9 - 10.5 @ 132 1.6x 60' . . just getting started
    Mar 2017
    Bedford, Texas
    Depends on how many bottles you can fit in the back :-D
    Seriously though, that is an odd question. Brake fluid capacity isn't usually something one considers, even when doing a flush. We usually just buy a couple bottles and let it flush through following the normal brake bleed process.
    What is the issue leading to the capacity question?
    Jan 2017
    Quote Originally Posted by bklynmag View Post
    I want to change it just for maintenance.
    Sent from my iPhone
    Jan 2017
    Sent from my iPhone
    Jan 2017
    I want to replace the old liquid with new liquid
    Sent from my iPhone
    Mar 2017
    Bedford, Texas
    Just get a couple bottles of the proper fluid and follow the bleeding sequence, one caliper at a time until clear fluid flows from the caliper you're bleeding. Then move to the next one.
    Top off the master cylinder as needed. Don't let it get empty.
    Thanks Don Renegade thanked for this post
    Nov 2007
    NorCal
    I would think 2 would get it done with extra needed during flush/bleeding.
    X E Ryder
    Just Another Motorhead, Really.
    (midlife crisis activated)
    Mar 2017
    Bedford, Texas
    It could probably be done with 1 big bottle, but I always buy 2...just in case.
