Modern Muscle Performance Group
Results 1 to 6 of 6
    Aug 2016
    6.4 in a 05 Maggie R/T
    Ok I’ve done my research and want to see if anyone has pulled this off yet. I want to use a 6.4 long block, put a 6.1 intake, early 6.1 tonewheel, a comp cams cam lock( not the limiter), and a 6.1 pcm. It should run. Will need a tune after but should run.
    All the rest of my original 1st gen 5.7 stuff should plug and play.
    Any options on why it shouldn’t work. And cost will be cheap. I have an intake already and a 6.4 long block with a bad cam.
    Jan 2016
    Will all the accessories bolt on?
    Aug 2016
    Not sure on the accessories yet. Getting mixed answers.
    Apr 2018
    Boca Raton, Florida
    Pm me.
    2006 BB Chrysler 300C 6.4l Swap
    Tuned By Chris At Hotwireauto, SRT Exhaust/Dynamax Race Bullets, 6&4 Piston Brembos, Lmi V2, Tranzformer, BT Catch Can, SRT Wheels, Street Edge Coilovers, SPC Upper Control Arms/Rear Bushings
    Aug 2016
    Thanks I will.
    Apr 2019
    Front timing cover is thicker (due to the VVT) and the accessory drive sticks farther out to match. PS pump from the 11-14 LD is different as well, lines up with the belt drive but doesn't have a remote reservoir; not sure on the pressure output/if it's compatible in an older LX. Alter a few things and everything drops right in. I was thinking about this swap, especially after driving a factory 392 for the first time lol. Is it a non-MDS engine or you planning to delete it anyway (which I assume so since you want to use a 6.1 PCM, though not necessary)?
