Modern Muscle Performance Group
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 46
  1. #31
    Dec 2012
    Ajax Ontario Canada
    I have more time in the headers than the rest combined. Had to stop when it got cold. Should be back at it in April. Just tailpipes, cold air intake and some wiring and its running.
    That Princess auto engine stand needs some modifying, its not very good.
  2. #32
    Nov 2017
    Warren, Oh
    That looks like an awesome project! Looks nice
    03 Ram 392 Stroker
  3. #33
    Dec 2014
    Nice work documenting this swap. I always wanted to see someone do a GEN III Hemi in a 87 Dak. The core support is much more shallow compared to the 91 and up Daks.. Great job with all of the fabrication you've done. Have you made any further progress thus far. Can't wait to see the finished product.
    13 Durango R/T
    13 M6 Challenger R/T
    02 M5 Dakota QC Sport
    91 TKO 600 Dakota CC
    63 Dart 3 on da Tree
  4. #34
    Dec 2012
    Ajax Ontario Canada
    Its on hold at the moment, doing some house reno's. Will get back at it soon.
  5. #35
    Dec 2014
    I understand that. I’ll be keeping my eyes out on this when you get back on it. I always wanted to put one in my old 87 Dak
  6. #36
    Dec 2012
    Ajax Ontario Canada
    I'm gearing up to continue working on the dak. Was too busy last year. I'm switching the efi controller to the holley terminater x that was just released. It can go under the hood. I have no room inside the truck.
    I just have to swap some connectors as the holley has the newer ones.
    Going to come up with a way to prime the engine. I don't like the flexible upper rad hose so might make one out of stainless tubing.
    I have a few things that need to occupy the same space so its getting tight up front.
    I'm hoping to have it running in April.
  7. #37
    Dec 2014
    Keep up the good work. You would create quite a bit more room by swapping the rad core honestly. Either way you go, you are accomplishing something most people haven’t tried as of yet.
  8. #38
    Mar 2016
    DE
    I may be mounting my rad in the bed to give plenty of room up front.
    Likes 91DakBuilder liked this post
  9. #39
    Dec 2014
    That would certainly give you more room.
  10. #40
    Dec 2012
    Ajax Ontario Canada
    I don't really like the idea of a bed mounted rad. I also don't want to change the front.
    If I have to I will modify an aluminum rad and put the upper rad hose where I want it. I'm not against modifying the rad support, I do need room for the ac condenser.
    If I move the battery it would solve the problem I have right now. I'm going to try to run the cold air on the upper rad hose side first and see if I can make it work.
    I will do things the harder way if I think its better.
    DBL.DWN what are you building?
  11. #41
    Dec 2014
    I’m building this, a 13 Challenger & a 63 Dart. Lots of projects in my life.
  12. #42
    Mar 2016
    DE
    twin turbo 5.7L 01 reg cab Dakota. Going to be mostly a drag truck tho. If i put the turbos up front then ill bed mount the rad. but ill try to stick them close to the fire wall.
    I'm starting the chassis work now. thinking 25.3 or 25.5 spec.
  13. #43
    Dec 2012
    Ajax Ontario Canada
    Cool projects.
    I ordered a 2003 4.7 5 speed dakota back in 2002. I wanted to put a hemi in it but emissions were a concern.
    It was why I picked the 87 as anything 88 and newer needed emission test, now they stopped doing them.
    Likes DBL.DWN liked this post
  14. #44
    Dec 2012
    Ajax Ontario Canada
    I have made some progress. Tail pipes just need final welding, gas tank is in for last time, cold air tube is done, holley terminator efi is almost completely wired. I had it powered up to figure out the tps wires. It should be running in the next couple weeks. I want to go over some stuff before I drive it.
  15. #45
    Dec 2012
    Ajax Ontario Canada
    I fired it up today, started right away. I still need to finish a few things. Just wanted to hear it run.
    Gas tank is not venting, have to figure that out. Just have to clean up wiring. Cold air intake is loud.
    I used the dakota voltage regulator to run the alternator. Only had it run for a minute. I made a timing map based on a ls3.
