Results 1 to 15 of 15
    Oct 2016
    Austin TX
    2018 Challenger SP to HC build
    So im starting with my 2018 indigo blue challenger. I was thinking about building the 392 but want to do a little something different. Im looking at purchasing a wrecked HC at a auction and transplanting the 6.2 into my SP. I want to keep the RT hood and bumper and everything else. Then ill do a few mods from there. Besides the motor, ECU, wiring harness, gauge cluster, boost pump, supercharger coolant bottle. Please dont say it would be cheaper to trade it in and stuff like that. This is the direction I want to go so im set in that. What else would I need to make this work? Here are a few pics and sorry for the dirty car its been raining every other day. Day 1 tint, Pinstripe removal and mid muffler delete, No drill plate bracket Last week HR5's with 275 and 315 az850's, Sidemarker tint, Black fuel door, Evil bee badge
    Semper Fi!
    Thanks ronan978 thanked for this post
    Aug 2016
    LINY
    Sounds like a fun build !!!! Good luck , we’ll all be watching/waiting.
    Personally I would never tell you to go buy a cat , I say BUILD IT !!!!!
    16’ charger Scatpack
    Forged 392 based 426 stroker, Arrington phase four Apache heads, custom grind cam , ported and matched 6.1 manifold, long tube headers , solo performance cutback ,ati pulley and pinned crank , custom cai , Tba diff brace with 3.70’s out back and 30” et r’s
    Thanks Ivey_usmc thanked for this post
    Likes Ivey_usmc liked this post
    Oct 2016
    Austin TX
    I appreciate it. Your one of the 1st.
    Dec 2007
    Riverside, California
    The HC hood is an imperative. It is designed with two additional holes as heat extractors. That supercharger generates a lot of its own heat and it needs to go somewhere.
    The bumper is also integral to the HC, as the fog light openings act as inlet ducts to cool the oil and trans coolers that are right behind them. This is why HC's don't have fogs. No place for them.
    Of course, if you're running the external HC coolers, you'll need new front wheel well liners and all the plastic diverter duct work unique to the HC front bumper. The liners have screened openings in them, to allow air to extract from the coolers, and the duct and diverter parts direct air to the coolers and the intercooler. Very important...
    You're going to want to upgrade the brakes to the 6 piston fronts and 4 piston rears... but that's only part of the stopping story.
    Below triple digit speeds, the HC non-sequential trans dumps gears and acts as an engine brake, under aggressive stopping conditions (like a manual shift would). So... are you upgrading the trans, too?
    These are my initial thoughts...
    Bob
    http://www.luxte.ch
    Lux Technologies
    Oct 2016
    Austin TX
    Hey Bob, Ill have a wrecked donor HC to get parts from. Most have front end damage but I would like to find one hit in the rear or something. Ill be able to get the trans, full wiring harness and everything out. I was thinking about fabbing a bracket on either side and pulling the coolers partially into a modified brake duct where it redirects some air but does not take away from the brakes.The rt hood has 2 functional air inlets in the top. Do you think that would be enough for the blower?As far as the brakes ill get them from the donor car but would like to stick with the 4 pistons. The only difference is with the 6 pistons your stopping distance is a little shorter and they are not as susceptible to brake fade from my understanding.
    Dec 2007
    I'm coming from a 600hp 06 SRT Charger and I can tell you that the 6 piston Brembos are far superior, to the 4 piston version.
    No fade issues, with OEM pads. Just installed Centric two piece front rotors and one piece rears, with Powerstop Z26 pads, all around. No stopping issues, with the CF/ceramic compound, either, on my 15 Hellcat.
    The additional 2 holes, in the HC hood, are for heat EXTRACTION. The center scoop is air inlet. The design of the hood, creates a low pressure area, above the two additional holes and heat flows from the engine compartment, through them.
    I'm not saying it won't work, if you can get that air, from the RT hood, down on the SC, but that thing generates a lot of heat, on its own. It's not about mitigating heat soak, from the engine, to the SC, in this case.
    The relocation of the coolers is intriguing. It's all doable.
    Looking forward to watching the build progress.
    Bob
    Bob
    Oct 2016
    Austin TX
    Oh ok I see what you mean on the hood. Ill look into that. I want to build a modern sleeper lolIll keep this post updated as I build. Doing a lot more research before I pull the trigger on this. I appreciate your advise.
    Feb 2018
    Boca Raton, fl
    Met a guy in S. Florida at a car show, took a 06 Magnum and did a full Hellcat conversion and I mean full, inside and out, as if MOPAR made a modern day Hellcat Magnum. Extremely impressed. It's amazing the dimensions haven't changed that much, dash, console, steering, literally everthing worked from Hellcat. Something I'd love to do.
    Good luck
    2013 Chrysler 300S, Stock 6.4 BGE with 6.4 SRT cam, AIT 18% OD pulley, E-force 2.62 pulley(12.2 ld boost), fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, 3" Magnaflow Cat-back, FTI 2800 stall, Trans by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. aluminum rad. SRT fans. Brembo upgrade. Stage one MOPAR springs, XIX X39 22x9 +15 - 22x10.5 +22 with NITTO NT555 265/35R22 - 295/30R22 going in: TSP boosted Stage 4 226/235 582/582 117+4
    Oct 2016
    Austin TX
    Thanks
    Aug 2016
    LINY
    I’m going to have to say no to the 6pot brakes , there just a heavier unneeded brake system unless you are road coursing the car. The hp70, especially in track mode absolutely downshifts and engine brakes the car as well, but a built paramount hp70 would be your answer to handle the power.
    Mar 2016
    DE
    Good luck
    That sounds like a slick set up. I always wanted to build a magnum. They are sharp when done up.
    Sep 2007
    Warren Mi.
    I just finished this build. Let me know if you need help. I did a r/t track pack car with a 6 speed. You can use your bumper just remove the fog lights and the middle grill blanks and reinstall. Let me know if you need any help. It really wasn't a hard swap but parts are Expensive. @kmoneyone on Instagram: “Hellcat Swapped R/T!”
    Oct 2016
    Austin TX
    I PM ed you on IG thanks!
    Sep 2007
    Warren Mi.
    Working on one of these builds right now..
    Oct 2018
    Houston,TX
    Anything is possible with enough money. Good luck with your build.
    2018 Dodge Charger Daytona - Indigo Blue
    2018 Dodge Charger Hellcat - Plum Crazy Purple
    Instagram: @aviorHemi
