Results 1 to 6 of 6
Thread: Hellcat forged?
    Jan 2011
    Calabash, NC
    Hellcat forged?
    Like it says arethe pistons, crank, and rods forged in a hellcat?
    PB 0-60 3.24 MIR Raceway Drag Radials 6/18
    PB 60' 1.472 @ CF9 4/18
    PB ET 1/8 6.911 @ CF9 4/18
    PB MPH 1/8 101.32 @ The Rock 4/19
    PB ET 10.857 @ CF9 4/18
    PB MPH 127.29 @ Atco 11/18
    Dec 2012
    DFW, TX
    Stock Mopar 6.2L Hellcat SRT8 Shortblock
    The 6.2L Hellcat engine features a completely forged rotating assembly, unlike the stock 6.4L, 392 pistons which are hyperkinetic. From the factory this bottom end supports the Hellcat’s 707 crank horse power. Dodge is so confident in this configuration that it gives the Hellcat a 3 year / 36,000-mile powertrain warranty. The 6.2L features a 4.090" Bore & a 3.580" Stroke.
    Key Features
    • Pistons: Hellcat pistons are forged aluminum, with increased radii in center for added strength. The wrist pins have a diamond like coating improving contact pressure capabilities. Slightly dished to lower compression to 9.5. Larger ring lands ensuring durability. Similar to the Apache piston, the skirts come coated. The skirts on the Hellcat piston are notably larger.
    • Connecting Rod: The Hellcat rod is a full floating, powdered steel connecting rod with a bronze bushing. Chrysler upgraded the alloy for this rod over the stock 6.4L Apache. The top end of the connecting rod is tapered to reduce inertial mass.
    • Crankshaft: Forged, micro polished, induction hardened, and fillet rolled! Every hellcat crank has the main journals measured and based on that measurement one of 3 custom main bearings is selected, ensuring that no matter the variance in tolerance the main bearing is a perfect fit.
    • Block: The block is cast utilizing a high strength alloy and features water jackets that are extended to the piston’s bottom dead center location, providing optimal heat transfer capabilities. Additional material and webbing between the main bulk heads and on exterior faces add strength and rigidity.
    Jan 2011
    Calabash, NC
    would you know stock afr wot. and stock boost?
    Jun 2012
    D/FW, Tx
    Boost is around 11 psi.
    2005 Dodge Magnum RT.
    12/2016 - Inertia big valve heads, Eagle intake, non-MDS lifters, Spartan Plus cam, Shorty headers. 390 RWHP, 390 RWTQ. (Work by Inertia)
    01/2017 - Bilstein shocks, SLP 25% underdrive pulley. s/b 400 RWHP, 400 RWTQ now. (Work by me)
    10/2017 - Replaced engine mounts with 392SRT manual transmission, added police oil cooler, additional PS and Trans coolers, Mishimoto radiator. (Work by me)
    10/2017 - Replaced Torque Converter with FTI 3,200RPM, Installed 3.06:1 Getrag kit, one piece Al DSS DS, Billy Boat 3" Exh.
    11/2017 - Wilwood brakes with 15" front brakes. (Work by me)
    Jan 2011
    Calabash, NC
    Stock AFR at wot?
    Apr 2019
    Quote Originally Posted by CruzKing View Post
    Stock AFR at wot?
    Would be curious to know this as well.. Anyone know what a stock Hellcat's AFR is at WOT?
