Page 1 of 3 123 LastLast
Results 1 to 15 of 42
    Feb 2020
    Exclamation Anyone with AlfaOBD & SXT charger with STP?
    If so, can you take a read of the BCM and post up the number shown in "chassis type". I have a buddy that we are trying to get launch control to work but without the correct chassis type the ABS/EVIC won't show the message on the dash to apply the brakes and press the gas when launch is activated.
    I know what the chassis types are for challengers but chargers use different numbering. Thanks!
    Feb 2020
    Giving this thread a bump. Again all I need to know is what the chassis type number which can be found in the BCM log.
    Mar 2016
    N. GA
    Mercy, what year model at least?
    Feb 2020
    Well my buddy has a 2016 SXT charger so guess any +2015 SXT charger with factory equipped STP. Again just need the chassis type # so I can enable STP/launch like this:
    How to add STP & Launch control to an RT+ w/manual trans | Dodge Challenger Forum
    I originally posted all the details in the Alfaobd master thread but thought I would start my own thread as it will get quickly lost over there.
    AlfaOBD Master Thread.
    Feb 2020
    Covid Bump.
    Mar 2016
    N. GA
    Your not trying hard enough fella. You want too much hand holding silver platter treatment.
    Go to THIS FORUM THREAD and carefully read the 1st post and heed every word. Especially the backup instructions. Some of the following early threads are good too.
    Backups are not something one can use to overwrite, they are for comparisons. Every time you make one it adds it to the end of the last one.
    Bone up on norepad++ and the compare plug in.
    This is a partial copy from one of my backups. Chassis Type is listed in Vehicle Config 3:
    Good Luck
    Vehicle Config 3:
    Police Lighting Feature: Not set
    Power Lift Gate Present: Not set
    Power Right Sliding Door Present: Not set
    Power Left Sliding Door Present: Not set
    RKE System Present: Set
    Sunshade Present: Not set
    T-Case Type: Not present
    Fuel Capacity: 73 Liters
    Wheel Base: Not defined
    FOBIK Safe Enable: Set
    ELV Present: Not set
    Window Express Feature Configuration: Front windows express only
    Adjustable Pedal Feature Present (non-Memory): Not set
    Auto Headlamp Feature Present: Set
    Door Alert Feature Present: Not set
    Two Fuel Sending Units Present: Set
    Vehicle is an SRT: Set
    Disable Display of Radio Clock: Not set
    Chassis Type: Type 23
    Display Outside Temperature Present: Set
    HVAC Configuration: Dual Zone ATC
    Vehicle Brand: Dodge
    Display Compass Heading Present: Set
    Interior EC Mirror Present: Set
    ESCL system present: Not set
    High Intensity Discharge Head Lamps: Set
    Secondary Lock Present: Not set
    Liftgate/Trunk Type: Trunk
    Collision Mitigation System present: Not set
    Forward Collision Warning present: Not set
    Base TPM system present: Not set
    Premium TPM system present: Set
    Paddle Shift Feature Present: Not set
    Sport Mode Present: Set
    Feb 2020
    Really? Where was the hand holding when I figured out how to get enable launch control (read my thread on CT)? All I was asking was for a chassis type # for an SXT Charger with factory equipped STP.
    I am not a noobie to alfa...just a noobie on this forum. I would also not call myself a noobie on the CT forum.
    Thanks for the Chassis number though.
    BTW - the link that diboblo posted (see below) was all me...no hand holding or silver platters involved.
    Feb 2020
    BTW for you SXT charger owners that don't have STP you might want to give this a try:
    Performance Pages Present: Present
    Drive mode feature configuration: Set
    Memory drive mode sub-feature configuration: Set
    ESC drive mode sub-feature configuration: Set
    Chassis Type: Type 23 (24 is the chassis type for a non-STP - hopefully the number gapi provided above is correct) Update: gupi gave me the chassis number off his 2013 RT+ so it won't work.
    Super trac pack present: Set
    Once all those changes are made you need to re-initialize the ABS module (follow the instructions given by AlfaOBD GUI).
    Now how is that for silver platter, hand holding?
    Feb 2020
    Good Luck
    Vehicle Config 3:
    Wait, so what vehicle is this off of? Is this a partial log from your 2013 Charger RT+?
    Jesus...can't you read?! I am looking for a 2015+ SXT with factory equipped STP chassis type #. Don't bother replying because your posts are only good for two things...Jack and Sh!t.
    Again folks I am looking for the chassis number for a 2015 SXT Charger equipped with STP. I need this number so I can enable STP/Launch control on my buddies charger...like I did for my challenger. The chassis number is not something that can be easily found or available on the web...I have looked.
    Feb 2020
    So folks this is what I have been able to figure out in terms of chassis code
    non-STP Charger SXT = 24
    STP Charger SXT = 34
    non-STP Charger RT = 23
    non-STP Challenger SXT = 44
    STP Challenger SXT = ??
    non-STP Challenger RT M6 = 76
    non-STP Challenger RT A8 = 44
    STP Challenger RT M6 = 77
    STP Challenger GT = 68
    STP Challenger SP A8 = 530 HP Chassis
    non-STP 300S = 25
    Feb 2018
    Tampa Florida
    Hey I will add one 2017 Chrysler 300S. 5.7 with all options... SafetyTec Plus, Heated and Cooled Seats, Sunroof, Hids, Nav.
    Chassis Type 25
    I would also like to figure out how to active Launch Control, Adjust Transmission and Steering.
    I have turned them on and they show in the uconnect. I just can not get either to work.
    Feb 2020
    Quote Originally Posted by Lenny H View Post
    Chassis Type 25
    Yup you need the chassis number for an STP version of a 300S and then re-initialize ABS module to take affect.
    Feb 2018
    Tampa Florida
    You are much more experience then me here...….I see you posted earlier that Type 27 was also a 300. Do you know what year that one was?
    Feb 2020
    Sorry that was a typo...was adding your value but my fat fingers hit 7 instead of 5. I guess you can try the range of numbers I posted and see if you can get it to work. A member on the CT forum had and automatic challenger and he tried several different numbers ranging from the GT to SP and they did not work. Then he tried the RT manual number 77 and got his launch control to work. You will know if the number is no good as the ABS will still flag a mismatch config code.
    Oh and don't you know I am not experienced...my hand was held and all this was given to me on a silver platter.
    Feb 2018
    Tampa Florida
    Quote Originally Posted by Challytatum View Post
    Thanks Man.... I will give it a try
