Results 16 to 30 of 44
  1. #16
    Jun 2019
    Alexandria, VA
    ChallyTatum,
    Thanks for creating a repository of chassis codes. I thought I read on your CT thread that you are no able to fully disable ESC/TSC by holding down the traction control
    button. Is this correct?
    Was this accomplished through adding performance control and adjust to the correct chassis #?
    Im following closely as I have a ‘16 Charger R/T (non STP) and would like to add the full ESC off functionality.
  2. #17
    Feb 2020
    Holding down the TC button disables stability...I showed the difference in my CT thread. Before I would just get Sport mode TC deactivation which would let me do burnout but after enabling STP I can not turn off stability so I no longer have to fight it when I do donuts. Before with Tazer holding the button down would disable everything including ABS and would require a restart to enable it. Turning off stability is enough to allow you to do any crazy driving without sacrificing ABS.
    https://www.challengertalk.com/threa...5/post-8553109
  3. #18
    Jun 2019
    Alexandria, VA
    Good to know! So, changing the chassis code is needed just for activating launch control, correct?
  4. #19
    Feb 2020
    Quote Originally Posted by 16PCRT View Post
    Yes, the chassis number is needed to get the EVIC to display the instructions when launch control is activated from performance control menu. Without the right chassis number, when you activate launch the EVIC does not display anything and hence launch will not activate.
  5. #20
    Feb 2020
    I am getting the impression no one has an Charger SXT with STP.
  6. #21
    Jun 2004
    Bloomingdale, IL
    Quote Originally Posted by Challytatum View Post
    Sorry, I don't visit this forum as often as I used to....I have an SXT charger w/ STP. What is it you need?
    My wife says I never listen to her...or something like that.
  7. #22
    Feb 2020
    Quote Originally Posted by zonian View Post
    Looking for a read from alfaOBD of the BCM on a +2015 charger STX factory equipped with STP.
  8. #23
    Jun 2004
    Bloomingdale, IL
    I have a 2018. How do I get this??
  9. #24
    Feb 2020
    2018 should work for me as well If you are running the android version it is explained here.
    https://www.lxforums.com/board/general-lx-discussion-3rd-gen-2015-/412142-alfaobd-master-thread.html?highlight=alfaobd
  10. #25
    Jun 2004
    Bloomingdale, IL
    Whoa...that's $50 for alfaobd...that's not gonna happen...sorry.
  11. #26
    Feb 2020
    I thought the free version allows the BCM to be logged, you just can't run the active diagnostics and config change? IMO anyone with an FCA vehicle that does their own work should invest in the software and obdlink MX dongle. It can do so much...read codes that only professional scan tools can read (i.e. ABS, HVAC...ect). It can also do some pretty cool stuff like enable launch control, change odometer mileage (handy if you ever need to replace the cluster) and much more. Oh and you should not need a bypass cable...I read my buddy's 2018 Challenger BCM without one.
  12. #27
    Jun 2004
    Bloomingdale, IL
    Hmmn. I can try the free version.
  13. #28
    Mar 2020
    Free version worked for me until I was ready to buy the full version and turn on my PP's. Did multiple reads of more than just my car.
  14. #29
    Feb 2020
    Any luck getting a read of the BCM?
  15. #30
    Feb 2020
    @zonian have you tried the free version?
