Results 1 to 13 of 13
Thread: 3.90 gears
    Jan 2020
    3.90 gears
    Hi guys,
    First post ever, I have done some research and wanted to get some additional insight on this potential gear swap I’m thinking about. I have an A8 scat, thinking about swapping to 3.90 gears to increase the fun factor. Not worried about 1/4 mile time or anything, I just have the occasional street fun when I ride with my mopar buddies. Now you guys are way more informed than me so I wanted to ask for opinions.. is the gear swap a worthy swap? Any pros/cons that come to mind? I do have a tuned PCM/TCM, would I need to get that retuned if I do the swap? What type of differences can I look forward to with the swap?
    Many Thanks!
    Jun 2018
    Quote Originally Posted by billet_6.4 View Post
    Hi guys,
    Many Thanks!
    No tuning necessary at all. Down side is gonna be say good bye to your traction. 3.90 is big jump imo.
    Aug 2016
    LINY
    It's an easy direct swap. No changes need at all. If you're not chasing times, its a very rewarding mod. Traction will be become an issue. I run a 3.70 on mine with a 315/50/17 ET r. Fun factor is increased tenfold
    Sent from my SM-G988U using Tapatalk
    16’ charger Scatpack
    Forged 392 based 426 stroker, Arrington phase four Apache heads, custom grind cam , ported and matched 6.1 manifold, long tube headers , solo performance cutback ,ati pulley and pinned crank , custom cai , Tba diff brace with 3.70’s out back and 30” et r’s
    Jan 2020
    Awesome, thanks for you guys' opinions!
    Jun 2019
    What does the car come with stock?
    May 2015
    Louisiana
    Quote Originally Posted by Grand_hustle17 View Post
    A8 Scat Pack has 3.09, the M6 Challenger Scat has 3.90.
    Jun 2013
    I regret my 391 but then again I'm a 5speed. If I had one more gear I bet that would make me change my mind. Doesn't really apply to you but you will love it. Best mod I've installed
    May 2015
    Louisiana
    For Scat Pack or any A8 with 3.0X gears, if you want to know what it will be like on the highway going to a 3.90, just get out there in 7th gear instead of 8th and it will be almost exactly the same. Yes, 7th with a 3.09 is the same as 8th with a 3.90. Gives you an idea what the rpms will be like and if that will work for you.
    Aug 2016
    A8 changing from 3.09 to 3.90 will increase 500 RPM in 8th gear.
    Jun 2019
    Im assuming this kills 1/4 to help top end?
    Aug 2016
    No, 3.90 will gain .2 in the 1/8. back half will not change
    Likes Jay Z, Grand_hustle17 liked this post
    Jun 2019
    Quote Originally Posted by MXS67454 View Post
    Gotcha.. seen one vid, guy ran [email protected] I was a tad intrigued. I currently run 7.4 in the 8th but at 92-93mph. Made me raise my brows lmao. Any full 1/4 testing lurking around?
    Feb 2017
    I also run the 3.70 gears in my Scat and according to the in car timer I went from 12 0s to 11 7s in the quarter mile, now I haven't been to a track, I am going by the in car timer
